.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _py_pi5_10s:
3.1.13 GAME - 10 Second
Next, follow me to make a game device to challenge your concentration.
Tie the tilt switch to a stick to make a magic wand. Shake the wand, the
4-digit segment display will start counting, shake again will let it
stop counting. If you succeed in keeping the displayed count at
**10.00**, then you win. You can play the game with your friends to see
who is the time wizard.
.. image:: ../python_pi5/img/4.1.18_game_10_second_list.png
:width: 800
:align: center
.. It's definitely convenient to buy a whole kit, here's the link:
.. .. list-table::
.. :widths: 20 20 20
.. :header-rows: 1
.. * - Name
.. - ITEMS IN THIS KIT
.. - LINK
.. * - Raphael Kit
.. - 337
.. - |link_Raphael_kit|
.. You can also buy them separately from the links below.
.. .. list-table::
.. :widths: 30 20
.. :header-rows: 1
.. * - COMPONENT INTRODUCTION
.. - PURCHASE LINK
.. * - :ref:`gpio_extension_board`
.. - |link_gpio_board_buy|
.. * - :ref:`breadboard`
.. - |link_breadboard_buy|
.. * - :ref:`wires`
.. - |link_wires_buy|
.. * - :ref:`resistor`
.. - |link_resistor_buy|
.. * - :ref:`4_digit`
.. * - :ref:`74hc595`
.. - |link_74hc595_buy|
.. * - :ref:`tilt_switch`
Schematic Diagram
GPIO17 Pin 11 0 17
GPIO27 Pin 13 2 27
GPIO22 Pin 15 3 22
SPIMOSI Pin 19 12 10
GPIO18 Pin 12 1 18
GPIO23 Pin 16 4 23
GPIO24 Pin 18 5 24
GPIO26 Pin 37 25 26
.. image:: ../python_pi5/img/4.1.18_game_10_second_schematic.png
:align: center
Experimental Procedures
**Step 1**: Build the circuit.
.. image:: ../python_pi5/img/4.1.18_game_10_second_circuit.png
**Step 2**: Go to the folder of the code.
.. raw:: html
.. code-block::
**Step 3**: Run the executable file.
.. raw:: html
.. code-block::
sudo python3 3.1.13_GAME_10Second.py
Shake the wand, the 4-digit segment display will start counting, shake
again will let it stop counting. If you succeed in keeping the displayed
count at **10.00**, then you win. Shake it one more time to start the
next round of the game.
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python-pi5``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
from gpiozero import OutputDevice, Button
import threading
# Initialize the button connected to GPIO 26
sensorPin = Button(26)
# Define GPIO pins connected to the 74HC595 shift register
SDI = OutputDevice(24) # Serial Data Input
RCLK = OutputDevice(23) # Register Clock
SRCLK = OutputDevice(18) # Shift Register Clock
# Define GPIO pins for digit selection on the 7-segment display
placePin = [OutputDevice(pin) for pin in (10, 22, 27, 17)]
# Define segment codes for numbers 0 to 9 on the 7-segment display
# Counter and timer variables
counter = 0
timer1 = None
gameState = 0
def clearDisplay():
""" Clear all segments on the 7-segment display. """
for _ in range(8):
SDI.on()
SRCLK.on()
SRCLK.off()
RCLK.on()
RCLK.off()
def hc595_shift(data):
""" Shift data to the 74HC595 shift register to display a digit. """
for i in range(8):
SDI.value = 0x80 & (data << i)
SRCLK.on()
SRCLK.off()
RCLK.on()
RCLK.off()
def pickDigit(digit):
""" Select which digit to display on the 7-segment display. """
for pin in placePin:
pin.off()
placePin[digit].on()
def display():
""" Display the current counter value on the 7-segment display. """
global counter
clearDisplay()
pickDigit(0)
clearDisplay()
pickDigit(1)
hc595_shift(number[counter % 100 // 10])
clearDisplay()
pickDigit(2)
hc595_shift(number[counter % 1000 // 100] - 0x80)
clearDisplay()
pickDigit(3)
hc595_shift(number[counter % 10000 // 1000])
def stateChange():
""" Handle state changes for the counter based on button presses. """
global gameState, counter, timer1
if gameState == 0:
counter = 0
time.sleep(1)
timer()
elif gameState == 1 and timer1 is not None:
timer1.cancel()
time.sleep(1)
gameState = (gameState + 1) % 2
def loop():
""" Main loop to check for button presses and update the display. """
global counter
currentState = 0
lastState = 0
display()
currentState = sensorPin.value
stateChange()
lastState = currentState
def timer():
""" Timer function that increments the counter every 0.01 second. """
global counter, timer1
timer1 = threading.Timer(0.01, timer)
timer1.start()
counter += 1
loop()
if timer1:
timer1.cancel()
**Code Explanation**
#. The script begins by importing necessary modules. The ``gpiozero`` library is used for interfacing with GPIO devices like buttons, and ``time`` and ``threading`` modules may be used for handling timing-related tasks or concurrent operations.
import threading
#. Initializes a ``Button`` object from the GPIO Zero library, connecting it to GPIO pin 26. This setup allows for the detection of button presses.
#. Initializes GPIO pins connected to the shift register's Serial Data Input (SDI), Register Clock Input (RCLK), and Shift Register Clock Input (SRCLK).
#. Initializes the pins for each digit of the 7-segment display and defines the binary codes for displaying numbers 0-9.
#. Functions to control the 7-segment display. ``clearDisplay`` turns off all segments, ``hc595_shift`` shifts data into the shift register, and ``pickDigit`` activates a specific digit on the display.
def clearDisplay():
for _ in range(8):
SDI.on()
SRCLK.on()
SRCLK.off()
RCLK.on()
RCLK.off()
for i in range(8):
SRCLK.on()
SRCLK.off()
RCLK.on()
RCLK.off()
pin.off()
#. Function to display the current value of the counter on the 7-segment display.
def display():
global counter
clearDisplay()
pickDigit(0)
clearDisplay()
pickDigit(1)
clearDisplay()
pickDigit(2)
clearDisplay()
pickDigit(3)
#. Function to handle state changes (start/stop) of the counter based on button presses.
def stateChange():
if gameState == 0:
counter = 0
time.sleep(1)
timer()
timer1.cancel()
time.sleep(1)
#. Main loop that continuously checks the button state and updates the display. It calls ``stateChange`` when the button state changes.
def loop():
global counter
currentState = 0
lastState = 0
display()
stateChange()
#. Timer function that increments the counter at a regular interval (every 0.01 second).
def timer():
timer1.start()
counter += 1
#. Executes the main loop and allows for a clean exit from the program using a keyboard interrupt (Ctrl+C).
loop()
if timer1:
timer1.cancel()
