.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _2.2.2_py_pi5: 2.2.2 Thermistor ================ .. note:: .. image:: ../img/mcp3008_and_adc0834.jpg :width: 25% :align: left Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section. Introduction ------------ Just like photoresistor can sense light, thermistor is a temperature sensitive electronic device that can be used for realizing functions of temperature control, such as making a heat alarm. Required Components ------------------------------ In this project, we need the following components. .. image:: ../python_pi5/img/2.2.2_thermistor_list.png .. It's definitely convenient to buy a whole kit, here's the link: .. .. list-table:: .. :widths: 20 20 20 .. :header-rows: 1 .. * - Name .. - ITEMS IN THIS KIT .. - LINK .. * - Raphael Kit .. - 337 .. - |link_Raphael_kit| .. You can also buy them separately from the links below. .. .. list-table:: .. :widths: 30 20 .. :header-rows: 1 .. * - COMPONENT INTRODUCTION .. - PURCHASE LINK .. * - :ref:`gpio_extension_board` .. - |link_gpio_board_buy| .. * - :ref:`breadboard` .. - |link_breadboard_buy| .. * - :ref:`wires` .. - |link_wires_buy| .. * - :ref:`resistor` .. - |link_resistor_buy| .. * - :ref:`thermistor` .. - |link_thermistor_buy| .. * - :ref:`adc0834` .. - \- Schematic Diagram ----------------- .. image:: ../python_pi5/img/2.2.2_thermistor_schematic_1.png .. image:: ../python_pi5/img/2.2.2_thermistor_schematic_2.png Experimental Procedures ----------------------- **Step 1:** Build the circuit. .. image:: ../python_pi5/img/2.2.2_thermistor_circuit.png **Step 2:** Go to the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/python-pi5 **Step 3:** Run the executable file .. raw:: html .. code-block:: sudo python3 2.2.2_Thermistor.py With the code run, the thermistor detects ambient temperature which will be printed on the screen once it finishes the program calculation. .. warning:: If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc` **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python-pi5``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python #!/usr/bin/env python3 # -*- coding: utf-8 -*- import ADC0834 import time import math # Initialize the ADC0834 module ADC0834.setup() # Run the process in a try-except block try: while True: # Read the analog value from the sensor analogVal = ADC0834.getResult() # Convert the analog value to a voltage Vr = 5 * float(analogVal) / 255 # Calculate the resistance of the thermistor Rt = 10000 * Vr / (5 - Vr) # Calculate the temperature in Kelvin temp = 1 / (((math.log(Rt / 10000)) / 3950) + (1 / (273.15 + 25))) # Convert Kelvin to Celsius Cel = temp - 273.15 # Convert Celsius to Fahrenheit Fah = Cel * 1.8 + 32 # Print the temperature in both Celsius and Fahrenheit print('Celsius: %.2f C Fahrenheit: %.2f F' % (Cel, Fah)) # Wait for 0.2 seconds before the next read time.sleep(0.2) # Handle KeyboardInterrupt for graceful termination except KeyboardInterrupt: # Clean up ADC0834 resources ADC0834.destroy() **Code Explanation** #. This section imports the ADC0834 library for analog-to-digital conversion, the time library for implementing delays, and the math library for conducting mathematical operations. .. code-block:: python #!/usr/bin/env python3 # -*- coding: utf-8 -*- import ADC0834 import time import math #. Initializes the ADC0834 module to enable reading of analog values. .. code-block:: python # Initialize the ADC0834 module ADC0834.setup() #. Implements an infinite loop for continuous data reading. The loop reads the analog value from a thermistor, converts this value to voltage, calculates the thermistor's resistance, and then translates this resistance into temperature measurements in Kelvin, Celsius, and Fahrenheit. It also outputs the temperature readings in Celsius and Fahrenheit, pausing for 0.2 seconds between each reading. .. code-block:: python # Run the process in a try-except block try: while True: # Read the analog value from the sensor analogVal = ADC0834.getResult() # Convert the analog value to a voltage Vr = 5 * float(analogVal) / 255 # Calculate the resistance of the thermistor Rt = 10000 * Vr / (5 - Vr) # Calculate the temperature in Kelvin temp = 1 / (((math.log(Rt / 10000)) / 3950) + (1 / (273.15 + 25))) # Convert Kelvin to Celsius Cel = temp - 273.15 # Convert Celsius to Fahrenheit Fah = Cel * 1.8 + 32 # Print the temperature in both Celsius and Fahrenheit print('Celsius: %.2f C Fahrenheit: %.2f F' % (Cel, Fah)) # Wait for 0.2 seconds before the next read time.sleep(0.2) #. Catches a KeyboardInterrupt exception to gracefully terminate the program and includes clean-up instructions for the ADC0834 resources upon termination. .. code-block:: python # Handle KeyboardInterrupt for graceful termination except KeyboardInterrupt: # Clean up ADC0834 resources ADC0834.destroy()
