.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _2.1.1_py_pi5:
2.1.1 Button
In this project, we will learn how to turn on or off the LED by using a
button.
.. image:: ../python_pi5/img/2.1.1_Button_list.png
.. raw:: html
Schematic Diagram
Use a normally open button as the input of Raspberry Pi, the connection is shown in the schematic diagram below. When the button is pressed, the GPIO18 will turn into high level (3.3V). We can detect the state of the GPIO18 through programming. That is, if the GPIO18 turns into high level, it means the button is pressed. You can run the corresponding code when the button is pressed, and then the LED will light up.
.. note::
The longer pin of the LED is the anode and the shorter one is
the cathode.
.. image:: ../python_pi5/img/2.1.1_Button_schematic_1.png
.. image:: ../python_pi5/img/2.1.1_Button_schematic_2.png
Experimental Procedures
**Step 1**: Build the circuit.
.. image:: ../python_pi5/img/2.1.1_Button_circuit.png
**Step 2**: Open the code file.
.. raw:: html
.. code-block::
**Step 3**: Run the code.
.. raw:: html
.. code-block::
sudo python3 2.1.1_Button.py
Now, press the button and the LED will light up; release the button and the LED will go off.
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python-pi5``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
from gpiozero import LED, Button # Import LED and Button classes from gpiozero
from signal import pause # Import pause function from signal module
# Initialize an LED object on GPIO pin 17
led = LED(17)
# Initialize a Button object on GPIO pin 18
button = Button(18)
# Link the button's "when_pressed" event to the LED's on() method
button.when_pressed = led.on
# Link the button's "when_released" event to the LED's off() method
button.when_released = led.off
# Run an event loop that waits for button events and keeps the script running
pause()
**Code Explanation**
#. The script is written in Python3 and it imports ``LED`` and ``Button`` classes from the ``gpiozero`` library, and ``pause`` from the ``signal`` module.
#. Initializes an ``LED`` object on GPIO pin 17 and a ``Button`` object on GPIO pin 18.
led = LED(17)
button = Button(18)
#. Sets up event handlers so that the LED turns on when the button is pressed and turns off when the button is released.
#. This keeps the script running in an event loop, waiting for the button press and release events.
pause()
