.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _1.3.3_py_pi5: 1.3.3 Stepper Motor ==================== Introduction ------------ Stepper motors, due to their unique design, can be controlled to a high degree of accuracy without any feedback mechanisms. The shaft of a stepper, mounted with a series of magnets, is controlled by a series of electromagnetic coils that are charged positively and negatively in a specific sequence, precisely moving it forward or backward in small \"steps\". Required Components ------------------------------ In this project, we need the following components. .. image:: ../python_pi5/img/1.3.3_stepper_motor_list.png .. raw:: html
Schematic Diagram ----------------- .. image:: /python_pi5/img/1.3.3_stepper_motor_schematic.png Experimental Procedures ----------------------- **Step 1:** Build the circuit. .. image:: ../python_pi5/img/1.3.3_stepper_motor_circuit.png **Step 2:** Open the code file. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/python-pi5 **Step 3:** Run. .. raw:: html .. code-block:: sudo python3 1.3.3_StepperMotor.py As the code runs, the stepper motor will turn clockwise or anti-clockwise depending on your input \'a\' or \'c\'. .. warning:: If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc` **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python-pi5``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python #!/usr/bin/env python3 from gpiozero import OutputDevice from time import sleep # Initialize motor pins to GPIO pins 18, 23, 24, 25 motorPin = [OutputDevice(pin) for pin in (18, 23, 24, 25)] # Set motor rotation speed parameters rotationPerMinute = 15 stepsPerRevolution = 2048 # Calculate time to wait between each step for smooth motor operation stepSpeed = (60 / rotationPerMinute) / stepsPerRevolution def rotary(direction): """ Controls the rotation of the motor based on the specified direction. :param direction: 'c' for clockwise, 'a' for anti-clockwise """ if direction == 'c': # Execute the stepping sequence for clockwise rotation for j in range(4): for i in range(4): if 0x99 << j & (0x08 >> i): motorPin[i].on() else: motorPin[i].off() sleep(stepSpeed) elif direction == 'a': # Execute the stepping sequence for anti-clockwise rotation for j in range(4): for i in range(4): if 0x99 >> j & (0x08 >> i): motorPin[i].on() else: motorPin[i].off() sleep(stepSpeed) def loop(): """ Continuously prompts the user to select the motor rotation direction and controls the motor based on this input. """ while True: direction = input('Select motor direction a=anticlockwise, c=clockwise: ') if direction == 'c': print('Motor running clockwise\n') break elif direction == 'a': print('Motor running anti-clockwise\n') break else: print('Input error, please try again!') # Keep the motor rotating in the selected direction while True: rotary(direction) def destroy(): """ Safely turns off all motor pins, used for clean shutdown. """ for pin in motorPin: pin.off() # Main program execution try: loop() except KeyboardInterrupt: destroy() # Handle keyboard interrupt to safely shut down the motor **Code Explanation** #. This section imports necessary libraries. ``gpiozero`` for controlling GPIO pins and ``time`` for the sleep function used in timing control. .. code-block:: python #!/usr/bin/env python3 from gpiozero import OutputDevice from time import sleep #. Initializes GPIO pins 18, 23, 24, and 25 as output devices for controlling the stepper motor. .. code-block:: python # Initialize motor pins to GPIO pins 18, 23, 24, 25 motorPin = [OutputDevice(pin) for pin in (18, 23, 24, 25)] #. Sets the motor's rotation speed and calculates the time interval between each step for smooth operation. .. code-block:: python # Set motor rotation speed parameters rotationPerMinute = 15 stepsPerRevolution = 2048 # Calculate time to wait between each step for smooth motor operation stepSpeed = (60 / rotationPerMinute) / stepsPerRevolution #. The ``rotary`` function controls the motor's rotation. It uses bit manipulation and a stepping sequence to activate the motor pins in the correct order for either clockwise or anti-clockwise rotation. .. code-block:: python def rotary(direction): """ Controls the rotation of the motor based on the specified direction. :param direction: 'c' for clockwise, 'a' for anti-clockwise """ if direction == 'c': # Execute the stepping sequence for clockwise rotation for j in range(4): for i in range(4): if 0x99 << j & (0x08 >> i): motorPin[i].on() else: motorPin[i].off() sleep(stepSpeed) elif direction == 'a': # Execute the stepping sequence for anti-clockwise rotation for j in range(4): for i in range(4): if 0x99 >> j & (0x08 >> i): motorPin[i].on() else: motorPin[i].off() sleep(stepSpeed) #. This function continuously prompts the user to choose the motor rotation direction and controls the motor based on the input. .. code-block:: python def loop(): """ Continuously prompts the user to select the motor rotation direction and controls the motor based on this input. """ while True: direction = input('Select motor direction a=anticlockwise, c=clockwise: ') if direction == 'c': print('Motor running clockwise\n') break elif direction == 'a': print('Motor running anti-clockwise\n') break else: print('Input error, please try again!') # Keep the motor rotating in the selected direction while True: rotary(direction) #. The ``destroy`` function turns off all motor pins. It's used for a clean shutdown, ensuring that the motor stops safely when the program ends. .. code-block:: python def destroy(): """ Safely turns off all motor pins, used for clean shutdown. """ for pin in motorPin: pin.off() #. The main program calls ``loop`` and handles keyboard interrupts (like Ctrl+C) to safely shut down the motor using ``destroy``. .. code-block:: python # Main program execution try: loop() except KeyboardInterrupt: destroy() # Handle keyboard interrupt to safely shut down the motor
