.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _1.3.2_py_pi5:
1.3.2 Servo
In this project, we will learn how to make the servo rotate.
.. image:: ../python_pi5/img/1.3.2_servo_list.png
Schematic Diagram
.. image:: ../img/image337.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../img/image125.png
**Step 2**: Go to the folder of the code.
.. raw:: html
.. code-block::
**Step 3**: Run the executable file.
.. raw:: html
.. code-block::
sudo python3 1.3.2_Servo.py
After the program is executed, the servo will rotate from 0 degrees to 90 to 180 degrees, and then from 180 degrees to 90 to 0 degrees, in a circle.
.. warning::
If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc`
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python-pi5``. After modifying the code, you can run it directly to see the effect.
.. raw:: html
.. code-block:: python
from gpiozero import Servo
from time import sleep
# Set the GPIO pin number where the servo motor is connected
myGPIO = 18
# Define a correction factor to fine-tune servo pulse width
myCorrection = 0.45
maxPW = (2.0 + myCorrection) / 1000 # Calculate maximum pulse width
minPW = (1.0 - myCorrection) / 1000 # Calculate minimum pulse width
# Initialize the Servo object with custom pulse widths
servo = Servo(myGPIO, min_pulse_width=minPW, max_pulse_width=maxPW)
# Position the servo at the middle and wait
servo.mid()
print("mid") # Indicate current position
sleep(0.5) # Brief pause for 0.5 seconds
# Move the servo to its minimum position and wait
servo.min()
print("min") # Indicate current position
sleep(1) # Hold position for 1 second
# Return the servo to the middle position and wait
servo.mid()
# Move the servo to its maximum position and wait
servo.max()
print("max") # Indicate current position
# Gracefully terminate the script on a keyboard interrupt (Ctrl+C)
**Code Explanation**
#. These import statements bring in the ``Servo`` class for servo control and the ``sleep`` function for timing.
#. Sets the GPIO pin number 18 for connecting the servo motor.
myGPIO = 18
#. These lines define a correction factor and use it to calculate the maximum and minimum pulse widths for the servo, fine-tuning its movement range.
myCorrection = 0.45
#. Initializes the Servo object with the specified GPIO pin and custom pulse widths.
#. The `try` block contains a `while True` loop to continuously move the servo. The servo is positioned at mid, min, and max points, with each position printed and held for a specified duration.
servo.mid()
servo.min()
servo.mid()
servo.max()
