.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _1.1.5_py_pi5: 1.1.5 4-Digit 7-Segment Display ==================================== Introduction ----------------- Next, follow me to try to control the 4-digit 7-segment display. Required Components ------------------------------ In this project, we need the following components. .. image:: ../python_pi5/img/1.1.5_4_digit_list.png .. raw:: html
Schematic Diagram -------------------------- ============ ======== === T-Board Name physical BCM GPIO17 Pin 11 17 GPIO27 Pin 13 27 GPIO22 Pin 15 22 SPIMOSI Pin 19 10 GPIO18 Pin 12 18 GPIO23 Pin 16 23 GPIO24 Pin 18 24 ============ ======== === .. image:: ../python_pi5/img/1.1.5_4_digit_schmatic.png Experimental Procedures ----------------------------------- **Step 1**: Build the circuit. .. image:: ../python_pi5/img/1.1.5_4-Digit_circuit.png **Step 2:** Go to the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/python-pi5 **Step 3:** Run the executable file. .. raw:: html .. code-block:: sudo python3 1.1.5_4-Digit.py After the code runs, the program takes a count, increasing by 1 per second, and the 4 digit display displays the count. .. warning:: If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc` **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python-pi5``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python #!/usr/bin/env python3 from gpiozero import OutputDevice import time import threading # Define GPIO pins for the 74HC595 shift register SDI = OutputDevice(24) # Serial Data Input RCLK = OutputDevice(23) # Register Clock SRCLK = OutputDevice(18) # Shift Register Clock # Define GPIO pins for digit selection on the 7-segment display placePin = [OutputDevice(pin) for pin in (10, 22, 27, 17)] # Define segment codes for numbers 0-9 for the 7-segment display number = (0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90) counter = 0 # Initialize counter for display timer1 = 0 # Initialize timer for counter increment def clearDisplay(): """ Clear the 7-segment display. """ for _ in range(8): SDI.on() SRCLK.on() SRCLK.off() RCLK.on() RCLK.off() def hc595_shift(data): """ Shift a byte of data to the 74HC595 shift register. """ for i in range(8): SDI.value = 0x80 & (data << i) # Set SDI high/low based on data bit SRCLK.on() # Pulse the Shift Register Clock SRCLK.off() RCLK.on() # Latch data on the output by pulsing Register Clock RCLK.off() def pickDigit(digit): """ Select a digit for display on the 7-segment display. """ for pin in placePin: pin.off() # Turn off all digit selection pins placePin[digit].on() # Turn on the selected digit def timer(): """ Timer function to increment the counter every second. """ global counter, timer1 timer1 = threading.Timer(1.0, timer) # Reset timer for next increment timer1.start() counter += 1 # Increment counter print("%d" % counter) # Print current counter value def setup(): """ Setup initial state and start the timer. """ global timer1 timer1 = threading.Timer(1.0, timer) # Initialize and start the timer timer1.start() def loop(): """ Main loop to update the 7-segment display with counter value. """ global counter while True: for i in range(4): # Loop through each digit clearDisplay() # Clear display before setting new digit pickDigit(i) # Select digit for display # Choose the digit of counter to display digit = (counter // (10 ** i)) % 10 hc595_shift(number[digit]) # Shift digit value to 74HC595 time.sleep(0.001) # Short delay for display stability def destroy(): """ Cleanup GPIO resources and stop timer on exit. """ global timer1 timer1.cancel() # Stop the timer for device in [SDI, RCLK, SRCLK] + placePin: device.close() # Close GPIO devices try: setup() # Initialize the setup while True: loop() # Start the main loop except KeyboardInterrupt: # Handle script interruption (e.g., Ctrl+C) destroy() # Cleanup resources on exit **Code Explanation** #. These four pins control the common anode pins of the four-digit 7-segment displays. .. code-block:: python # Define GPIO pins for digit selection on the 7-segment display placePin = [OutputDevice(pin) for pin in (10, 22, 27, 17)] #. A segment code array from 0 to 9 in hexadecimal (common anode). .. code-block:: python # Define segment codes for numbers 0-9 for the 7-segment display number = (0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90) #. Initializes a timer that triggers the `timer` function every second. This sets up the recurring counter increment. .. code-block:: python def setup(): """ Setup initial state and start the timer. """ global timer1 timer1 = threading.Timer(1.0, timer) # Initialize and start the timer timer1.start() #. After Timer reaches 1.0s, the Timer function is called; add 1 to counter, and the Timer is used again to execute itself repeatedly every second. .. code-block:: python def timer(): """ Timer function to increment the counter every second. """ global counter, timer1 timer1 = threading.Timer(1.0, timer) # Reset timer for next increment timer1.start() counter += 1 # Increment counter print("%d" % counter) # Print current counter value #. Shifts a byte of data into the 74HC595 shift register, controlling the display segments. .. code-block:: python def hc595_shift(data): """ Shift a byte of data to the 74HC595 shift register. """ for i in range(8): SDI.value = 0x80 & (data << i) # Set SDI high/low based on data bit SRCLK.on() # Pulse the Shift Register Clock SRCLK.off() RCLK.on() # Latch data on the output by pulsing Register Clock RCLK.off() #. Continuously updates the display with the current counter value, showing each digit sequentially. .. code-block:: python def loop(): """ Main loop to update the 7-segment display with counter value. """ global counter while True: for i in range(4): # Loop through each digit clearDisplay() # Clear display before setting new digit pickDigit(i) # Select digit for display digit = (counter // (10 ** i)) % 10 hc595_shift(number[digit]) # Shift digit value to 74HC595 time.sleep(0.001) # Short delay for display stability #. Clears the 7-segment display by setting all segments off before displaying the next digit. .. code-block:: python def clearDisplay(): """ Clear the 7-segment display. """ for _ in range(8): SDI.on() SRCLK.on() SRCLK.off() RCLK.on() RCLK.off() #. Selects which digit of the 7-segment display to activate. Each digit is controlled by a separate GPIO pin. .. code-block:: python def pickDigit(digit): """ Select a digit for display on the 7-segment display. """ for pin in placePin: pin.off() # Turn off all digit selection pins placePin[digit].on() # Turn on the selected digit #. Properly releases the GPIO resources and stops the timer when the program is interrupted. .. code-block:: python except KeyboardInterrupt: # Handle script interruption (e.g., Ctrl+C) destroy() # Cleanup resources on exit
