.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
3.1.8 Overheat Monitor
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
You may want to make an overheat monitoring device that applies to
various situations, ex., in the factory, if we want to have an alarm and
the timely automatic turning off of the machine when there is a circuit
overheating. In this lesson, we will use thermistor, joystick, buzzer,
LED and LCD to make an smart temperature monitoring device whose
threshold is adjustable.
Components
.. image:: img/list_Overheat_Monitor.png
:align: center
.. image:: img/list_Overheat_Monitor2.png
:align: center
Schematic Diagram
GPIO17 Pin 11 0 17
GPIO18 Pin 12 1 18
GPIO27 Pin 13 2 27
GPIO22 Pin15 3 22
GPIO23 Pin16 4 23
GPIO24 Pin18 5 24
SDA1 Pin 3
SCL1 Pin 5
.. image:: img/Schematic_three_one8.png
:width: 700
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: img/image258.png
:width: 800
**Step 2**: Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/3.1.8/
**Step 3**: Compile the code.
.. raw:: html
.. code-block::
gcc 3.1.8_OverheatMonitor.c -lwiringPi -lm
**Step 4**: Run the executable file.
.. raw:: html
.. code-block::
As the code runs, the current temperature and the high-temperature
threshold **40** are displayed on **I2C LCD1602**. If the current
temperature is larger than the threshold, the buzzer and LED are started
to alarm you.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
**Joystick** here is for your pressing to adjust the high-temperature
threshold. Toggling the **Joystick** in the direction of X-axis and
Y-axis can adjust (turn up or down) the current high-temperature
threshold. Press the **Joystick** once again to reset the threshold to
initial value.
**Code Explanation**
.. code-block:: c
int get_joystick_value(){
uchar x_val;
uchar y_val;
x_val = get_ADC_Result(1);
y_val = get_ADC_Result(2);
if (x_val > 200){
else if(x_val < 50){
return -1;
else if(y_val > 200){
return -10;
else if(y_val < 50){
return 10;
else{
This function reads values of X and Y. If **X>200**, there will return
\"**1**\"; **X<50**, return \"**-1**\"; **y>200**, return
\"**-10**\", and **y<50**, return \"**10**\".
.. code-block:: c
void upper_tem_setting(){
write(0, 0, "Upper Adjust:");
int change = get_joystick_value();
upperTem = upperTem + change;
char str[6];
snprintf(str,3,"%d",upperTem);
write(0,1,str);
int len;
len = strlen(str);
write(len,1," ");
delay(100);
This function is for adjusting the threshold and displaying it on the
I2C LCD1602.
.. code-block:: c
double temperature(){
unsigned char temp_value;
temp_value = get_ADC_Result(0);
Vr = 5 * (double)(temp_value) / 255;
cel = temp - 273.15;
Fah = cel * 1.8 +32;
return cel;
Read the analog value of the **CH0** (thermistor) of **ADC0834** and
then convert it to temperature value.
.. code-block:: c
void monitoring_temp(){
char str[6];
double cel = temperature();
snprintf(str,6,"%.2f",cel);
write(0, 0, "Temp: ");
write(6, 0, str);
write(0, 1, "Upper: ");
write(7, 1, str);
delay(100);
if(cel >= upperTem){
digitalWrite(buzzPin, HIGH);
digitalWrite(LedPin, HIGH);
else if(cel < upperTem){
digitalWrite(buzzPin, LOW);
digitalWrite(LedPin, LOW);
to alarm you.
.. code-block:: c
int main(void)
setup();
int lastState =1;
int stage=0;
while (1)
int currentState = digitalRead(Joy_BtnPin);
if(currentState==1 && lastState == 0){
stage=(stage+1)%2;
delay(100);
lcd_clear();
lastState=currentState;
if (stage==1){
upper_tem_setting();
else{
monitoring_temp();
The function main() contains the whole program process as shown:
1) When the program starts, the initial value of **stage** is **0**, and
the current temperature and the high-temperature threshold **40** are
displayed on **I2C LCD1602**. If the current temperature is larger
than the threshold, the buzzer and the LED are started to alarm you.
2) Press the Joystick, and **stage** will be **1** and you can adjust
the high-temperature threshold. Toggling the Joystick in the
direction of X-axis and Y-axis can adjust (turn up or down) the
current threshold. Press the Joystick once again to reset the
threshold to initial value.
