.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
3.1.6 Motion Control
In this lesson, we will make a simple motion sensing and controlling
device. The MPU6050 is used as a sensor and the stepper motor as a
controlled device. With the MPU6050 mounted on the glove, you can
control the stepper motor by rotating your wrist.
Components
.. image:: img/list_Motion_Control.png
:align: center
Schematic Diagram
GPIO18 Pin 12 1 18
GPIO23 Pin 16 4 23
GPIO24 Pin 18 5 24
GPIO25 Pin 22 6 25
SDA1 Pin 3
SCL1 Pin 5
.. image:: img/Schematic_three_one6.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: img/image251.png
:width: 800
:align: center
**Step 2**: Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/3.1.6/
**Step 3**: Compile the code.
.. raw:: html
.. code-block::
gcc 3.1.6_MotionControl.c -lwiringPi -lm
**Step 4**: Run the executable file.
.. raw:: html
.. code-block::
As the code runs, if the tilt angle of **mpu6050** on the
`Y `__-`axis `__
is larger than **45** ℃, the stepper motor rotates anticlockwise; if
less than **-45** ℃, the stepper motor rotates clockwise.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
**Code Explanation**
.. code-block:: c
double mpu6050(){
acclX = read_word_2c(0x3B);
acclY = read_word_2c(0x3D);
acclZ = read_word_2c(0x3F);
acclX_scaled = acclX / 16384.0;
acclY_scaled = acclY / 16384.0;
acclZ_scaled = acclZ / 16384.0;
double angle=get_y_rotation(acclX_scaled, acclY_scaled, acclZ_scaled);
return angle;
mpu6050 gets the tilt angle in the direction of the Y-axis.
.. code-block:: c
void rotary(char direction){
if(direction == 'c'){
for(int j=0;j<4;j++){
for(int i=0;i<4;i++)
{digitalWrite(motorPin[i],0x99>>j & (0x08>>i));}
delayMicroseconds(stepSpeed);
else if(direction =='a'){
{digitalWrite(motorPin[i],0x99<>i));}
If the received direction **key** is \'**c**\', the stepper motor
rotates clockwise; if the **key** is \'**a**\', the motor rotates
anticlockwise. Refer to :ref:`1.3.3_stepper_c_pi5` for more details about
the calculation of the rotating direction of the stepper motor.
.. code-block:: c
int main()
setup();
double angle;
while(1) {
angle = mpu6050();
if (angle >=45){rotary('a');}
else if (angle<=-45){rotary('c');}
The tilt angle in the direction of the Y-axis is read from **mpu6050**,
and if it’s larger than **45** ℃, the stepper motor rotates
anticlockwise; if less than **-45** ℃, the stepper motor rotates
clockwise.
