.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! 3.1.5 Battery Indicator ============================ .. note:: .. image:: ../img/mcp3008_and_adc0834.jpg :width: 25% :align: left Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section. Introduction -------------- In this course, we will make a battery indicator device that can visually display the battery level on the LED Bargraph. Components ------------ .. image:: img/list_Battery_Indicator.png :align: center Schematic Diagram ------------------- ============ ======== ======== === T-Board Name physical wiringPi BCM GPIO17 Pin 11 0 17 GPIO18 Pin 12 1 18 GPIO27 Pin 13 2 27 GPIO25 Pin 22 6 25 GPIO12 Pin 32 26 12 GPIO16 Pin 36 27 16 GPIO20 Pin 38 28 20 GPIO21 Pin 40 29 21 GPIO5 Pin 29 21 5 GPIO6 Pin 31 22 6 GPIO13 Pin 33 23 13 GPIO19 Pin 35 24 19 GPIO26 Pin 37 25 26 ============ ======== ======== === .. image:: img/Schematic_three_one5.png :align: center Experimental Procedures ------------------------- **Step 1:** Build the circuit. .. image:: img/image248.png :width: 800 :align: center **Step 2:** Go to the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/c/3.1.5/ **Step 3:** Compile the code. .. raw:: html .. code-block:: gcc 3.1.5_BatteryIndicator.c -lwiringPi **Step 4:** Run the executable file. .. raw:: html .. code-block:: sudo ./a.out After the program runs, give the 3rd pin of ADC0834 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V). .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`. **Code Explanation** .. code-block:: c void LedBarGraph(int value){     for(int i=0;i<10;i++){         digitalWrite(pins[i],HIGH);     }     for(int i=0;i
