.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _3.1.4_c_pi5_mcp3008:
3.1.4 Smart Fan(MCP3008)
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
In this project, we will use motors, buttons and thermistors to make a
manual + automatic smart fan whose wind speed is adjustable.
.. image:: ../img/list2_Smart_Fan.png
:align: center
Schematic Diagram
SPICE0 Pin 24 10 8
SPIMOSI Pin 19 12 10
SPIMISO Pin 21 13 9
SPISCLK Pin 23 14 11
GPIO22 Pin 15 3 22
GPIO5 Pin 29 21 5
GPIO6 Pin 31 22 6
GPIO13 Pin 33 23 13
.. image:: ../img/schematic_3.1.4_smart_fan_mcp3008.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../img/july24_3.1.4_smart_fan_mcp3008.png
:align: center
.. note::
The power module can apply a 9V battery with the 9V Battery
Buckle in the kit. Insert the jumper cap of the power module into the 5V
bus strips of the breadboard.
.. image:: ../img/image118.jpeg
:align: center
**Step 2**: Get into the folder of the code.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/3.1.4-2/
**Step 3**: Compile.
.. raw:: html
.. code-block::
gcc 3.1.4_SmartFan.c -o SmartFan -lwiringPi -lm
**Step 4**: Run the executable file above.
.. raw:: html
.. code-block::
./SmartFan
As the code runs, start the fan by pressing the button. Every time you
press, 1 speed grade is adjusted up or down. There are **5** kinds of
speed grades: **0~4**. When set to the 4\ :sup:`th` speed grade and you
press the button, the fan stops working with a **0** wind speed.
Once the temperature goes up or down for more than 2℃, the speed
automatically gets 1-grade faster or slower.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
.. code-block:: c
#include
#include
#include
#include
#include
#define SPI_CHANNEL 0
#define SPI_SPEED 1000000
#define MotorPin1 21
#define MotorPin2 22
#define MotorEnable 23
#define BtnPin 3
int read_ADC(int channel)
unsigned char buffer[3];
buffer[0] = 1; // Start bit
buffer[1] = (8 + channel) << 4; // Single-ended mode and channel
buffer[2] = 0;
int result = ((buffer[1] & 3) << 8) | buffer[2];
return result;
int temperture()
int analogVal = read_ADC(0);
double Vr = 3.3 * analogVal / 1023.0; // Use 3.3V as Vref for MCP3008
double Rt = 10000.0 * Vr / (3.3 - Vr);
double temp = 1 / (((log(Rt / 10000.0)) / 3950.0) + (1 / (273.15 + 25.0)));
double cel = temp - 273.15;
double Fah = cel * 1.8 + 32;
printf("Celsius: %.2f C Fahrenheit: %.2f F\n", cel, Fah);
return (int)cel;
int motor(int level)
if (level == 0) {
digitalWrite(MotorEnable, LOW);
if (level >= 4) {
level = 4;
digitalWrite(MotorEnable, HIGH);
softPwmWrite(MotorPin1, level * 25);
return level;
void setup()
if (wiringPiSetup() == -1) {
printf("wiringPi setup failed!\n");
return;
printf("SPI setup failed!\n");
return;
softPwmCreate(MotorPin1, 0, 100);
softPwmCreate(MotorPin2, 0, 100);
pinMode(MotorEnable, OUTPUT);
pinMode(BtnPin, INPUT);
int main(void)
setup();
int currentState, lastState = 0;
int level = 0;
int currentTemp, markTemp = 0;
while (1) {
currentState = digitalRead(BtnPin);
currentTemp = temperture();
if (currentTemp <= 0) continue;
if (currentState == 1 && lastState == 0) {
level = (level + 1) % 5;
markTemp = currentTemp;
delay(500);
lastState = currentState;
if (level != 0) {
if (currentTemp - markTemp <= -2) {
level = level - 1;
if (currentTemp - markTemp >= 2) {
level = level + 1;
level = motor(level);
Code Explanation
.. code-block:: c
buffer[2] = 0;
return result;
This function is used to read analog input from MCP3008 on the specified channel.
It sends a 3-byte SPI command and returns a 10-bit digital value between 0–1023.
.. code-block:: c
int temperture()
return (int)cel;
The ``temperture()`` function reads the thermistor analog signal via MCP3008,
calculates voltage, resistance, then converts to Celsius and Fahrenheit using
the thermistor formula (Steinhart–Hart approximation).
.. code-block:: c
if (level == 0) {
if (level >= 4) {
level = 4;
return level;
This ``motor()`` function controls fan speed via PWM.
Level ranges from 0–4, where 0 turns the fan off and each level increases the duty cycle by 25%.
.. code-block:: c
void setup()
return;
return;
The ``setup()`` function initializes WiringPi, sets up SPI, configures PWM
and GPIO pins needed for motor control and button input.
.. code-block:: c
int main(void)
setup();
int level = 0;
while (1) {
delay(500);
if (level != 0) {
level = level - 1;
level = level + 1;
The ``main()`` function contains the program loop:
1. Constantly checks button state and reads current temperature.
2. On button press, fan level increases (cycles 0–4) and saves temperature.
3. If temperature changes by ±2°C, it auto-adjusts fan speed accordingly.
4. Calls ``motor(level)`` to update PWM output based on current level.
