.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
3.1.2 Welcome
In this project, we will use PIR to sense the movement of pedestrians,
and use servos, LED, buzzer to simulate the work of the sensor door of
the convenience store. When the pedestrian appears within the sensing
range of the PIR, the indicator light will be on, the door will be
opened, and the buzzer will play the opening bell.
Components
.. image:: img/list_Welcome.png
:align: center
Schematic Diagram
GPIO18 Pin 12 1 18
GPIO17 Pin 11 0 17
GPIO27 Pin 13 2 27
GPIO22 Pin 15 3 22
.. image:: img/Schematic_three_one2.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: img/image239.png
:width: 800
:align: center
**Step 2:** Change directory.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/3.1.2/
**Step 3:** Compile.
.. raw:: html
.. code-block::
gcc 3.1.2_Welcome.c -lwiringPi
**Step 4:** Run.
.. raw:: html
.. code-block::
After the code runs, if the PIR sensor detects someone passing by, the
door will automatically open (simulated by the servo), turn on the
indicator and play the doorbell music. After the doorbell music plays,
the system will automatically close the door and turn off the indicator
light, waiting for the next time someone passes by.
There are two potentiometers on
the PIR module: one is to adjust sensitivity and the other is to adjust
the detection distance. To make the PIR module work better, you
You need to turn both of them counterclockwise to the end.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
**Code Explanation**
.. code-block:: c
void setAngle(int pin, int angle){ //Create a funtion to control the angle of the servo.
if(angle < 0)
angle = 0;
if(angle > 180)
angle = 180;
softPwmWrite(pin,Map(angle, 0, 180, 5, 25));
Create a function, setAngle to write the angle in the servo that is
0-180.
.. code-block:: c
void doorbell(){
for(int i=0;i-1;i--){ //make servo rotate from maximum angle to minimum angle
setAngle(servoPin,i);
delay(1);
Create a closedoor function to simulate closing the door, turn off the
LED and let the servo turn from 180 degrees to 0 degree.
.. code-block:: c
void opendoor(){
digitalWrite(ledPin, HIGH); //led on
for(int i=0;i<181;i++){ //make servo rotate from minimum angle to maximum angle
delay(1);
doorbell();
closedoor();
The function opendoor() includes several parts: turn on the indicator
light, turn the servo (simulate the action of opening the door), play
the doorbell music of the convenience store, and call the function
closedoor() after playing music.
.. code-block:: c
int main(void)
if(softToneCreate(BuzPin) == -1){
printf("setup softTone failed !");
In the function main(), initialize library wiringPi and setup softTone,
then set ledPin to output state and pirPin to input state. If the PIR
sensor detects someone passing by, the function opendoor will be called
to simulate opening the door.
