.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! 3.1.11 Morse Code Generator ============================= Introduction ----------------- In this lesson, we'll make a Morse code generator, where you type in a series of English letters in the Raspberry Pi to make it appear as Morse code. Components --------------- .. image:: img/3.1.10.png :align: center Schematic Diagram ----------------------- ============ ======== ======== === T-Board Name physical wiringPi BCM GPIO17 Pin 11 0 17 GPIO22 Pin 15 3 22 ============ ======== ======== === .. image:: img/Schematic_three_one11.png :align: center Experimental Procedures ---------------------------- **Step 1:** Build the circuit. (Pay attention to poles of the buzzer: The one with + label is the positive pole and the other is the negative.) .. image:: img/image269.png :width: 800 **Step 2**: Open the code file. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/c/3.1.11/ **Step 3**: Compile the code. .. raw:: html .. code-block:: gcc 3.1.11_MorseCodeGenerator.c -lwiringPi **Step 4**: Run the executable file above. .. raw:: html .. code-block:: sudo ./a.out After the program runs, type a series of characters, and the buzzer and the LED will send the corresponding Morse code signals. .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`. **Code Explanation** .. code-block:: c struct MORSE{     char word;     unsigned char *code; }; struct MORSE morseDict[]= {     {'A',"01"}, {'B',"1000"}, {'C',"1010"}, {'D',"100"}, {'E',"0"},      {'F',"0010"}, {'G',"110"}, {'H',"0000"}, {'I',"00"}, {'J',"0111"},      {'K',"101"}, {'L',"0100"}, {'M',"11"}, {'N',"10"}, {'O',"111"},      {'P',"0110"}, {'Q',"1101"}, {'R',"010"}, {'S',"000"}, {'T',"1"},     {'U',"001"}, {'V',"0001"}, {'W',"011"}, {'X',"1001"}, {'Y',"1011"},      {'Z',"1100"},{'1',"01111"}, {'2',"00111"}, {'3',"00011"}, {'4',"00001"},      {'5',"00000"},{'6',"10000"}, {'7',"11000"}, {'8',"11100"}, {'9',"11110"},     {'0',"11111"},{'?',"001100"}, {'/',"10010"}, {',',"110011"}, {'.',"010101"},     {';',"101010"},{'!',"101011"}, {'@',"011010"}, {':',"111000"} }; This structure MORSE is the dictionary of the Morse code, containing characters A-Z, numbers 0-9 and marks \"?\" \"/\" \":\" \",\" \".\" \";\" \"!\" \"@\" . .. code-block:: c char *lookup(char key,struct MORSE *dict,int length) {     for (int i=0;i= 'a') && (c <= 'z'))         return c + ('A' - 'a');     return c; } char *strupr(char *str) {     char *orign=str;     for (; *str!='\0'; str++)         *str = toupper(*str); return orign; } Before coding, you need to unify the letters into capital letters. .. code-block:: c void main(){     setup();     char *code;     int length=8;     code = (char*)malloc(sizeof(char)*length);     while (1){         printf("Please input the messenger:"); delay(100);         scanf("%s",code);         code=strupr(code);         printf("%s\n",code); delay(100);         morsecode(code);     } } When you type the relevant characters with the keyboard, code=strupr(code) will convert the input letters to their capital form. Printf() then prints the clear text on the computer screen, and the morsecod() function causes the buzzer and the LED to emit Morse code. Note that the length of the input character mustn’t exceed the **length** (can be revised).
