.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _2.2.3_c_pi5:
2.2.3 DHT-11
The digital temperature and humidity sensor DHT11 is a composite sensor
that contains a calibrated digital signal output of temperature and
humidity. The technology of a dedicated digital modules collection and
the technology of the temperature and humidity sensing are applied to
ensure that the product has high reliability and excellent stability.
The sensors include a wet element resistive sensor and a NTC temperature
sensor and they are connected to a high performance 8-bit
microcontroller.
.. image:: ../img/list_2.2.3_dht-11.png
Schematic Diagram
.. image:: ../img/image326.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../img/image207.png
**Step 2:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/2.2.3/
**Step 3:** Compile the code.
.. raw:: html
.. code-block::
gcc 2.2.3_DHT.c -lwiringPi
**Step 4:** Run the executable file.
.. raw:: html
.. code-block::
After the code runs, the program will print the temperature and humidity
detected by DHT11 on the computer screen.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
**Code**
.. code-block:: c
#include
#include
#include
#include
#define MAXTIMINGS 85 // Maximum number of timing transitions
int dht11_dat[5] = {0, 0, 0, 0, 0}; // Data array to hold sensor values
// Function to read data from DHT11 sensor
void read_dht11_dat(int GPIOPIN)
uint8_t currState;
uint8_t laststate = HIGH;
uint8_t counter = 0;
uint8_t j = 0;
uint8_t i;
float f; // Temperature in Fahrenheit
// Reset data array before each read
dht11_dat[0] = dht11_dat[1] = dht11_dat[2] = dht11_dat[3] = dht11_dat[4] = 0;
// Pull pin down for 18 milliseconds to initiate communication
pinMode(GPIOPIN, OUTPUT);
digitalWrite(GPIOPIN, LOW);
delay(18);
// Then pull it up for 40 microseconds
digitalWrite(GPIOPIN, HIGH);
delayMicroseconds(40);
// Prepare to read the pin
pinMode(GPIOPIN, INPUT);
// Detect change and read data
for (i = 0; i < MAXTIMINGS; i++)
counter = 0;
// Count how long each state lasts
while (digitalRead(GPIOPIN) == laststate)
counter++;
delayMicroseconds(2);
if (counter == 255)
break;
// Save the current state
laststate = digitalRead(GPIOPIN);
if (counter == 255) break;
// Ignore first 3 transitions (DHT11 response signal)
if ((i >= 4) && (i % 2 == 0))
// Shift bits and store data
dht11_dat[j/8] <<= 1;
if (counter > 16)
dht11_dat[j/8] |= 1;
j++;
// Check if we received 40 bits (5 bytes) and verify checksum
if ((j >= 40) && (dht11_dat[4] == ((dht11_dat[0] + dht11_dat[1] + dht11_dat[2] + dht11_dat[3]) & 0xFF)) )
// Convert temperature to Fahrenheit
f = dht11_dat[2] * 9.0 / 5.0 + 32;
printf("Humidity = %d.%d %% Temperature = %d.%d °C (%.1f °F)\n",
dht11_dat[0], dht11_dat[1], dht11_dat[2], dht11_dat[3], f);
else
printf("Data not good, skip\n");
int main (void)
printf("Raspberry Pi wiringPi DHT11 Temperature test program\n");
// Initialize wiringPi using BCM GPIO pin numbering
if (wiringPiSetupGpio() == -1)
exit(1);
while(1)
// Read data from DHT11 connected to GPIO pin 17
read_dht11_dat(17);
delay(1000); // Wait 1 second before next read
**Code Explanation**
#. Include Headers: The code includes necessary headers for wiringPi functions and standard input/output.
.. code-block:: C
#include
#include
#include
#include
#. Define Constants:
* ``MAXTIMINGS``: The maximum number of timing transitions expected from the DHT11 sensor (85).
.. code-block:: C
#. Global Data Array:
* ``dht11_dat[5]``: An array to hold the 5 bytes of data received from the DHT11 sensor.
.. code-block:: C
#. Function ``read_dht11_dat(int GPIOPIN)``: Reads data from the DHT11 sensor connected to the specified GPIO pin.
* Initialization: Reset the dht11_dat array to zero before each read.
.. code-block:: C
* Start Signal: Pull the GPIO pin low for at least 18 milliseconds to signal the DHT11 to start sending data.
.. code-block:: C
delay(18); // 18 milliseconds
* Pull the GPIO pin high for 40 microseconds.
.. code-block:: C
delayMicroseconds(40); // 40 microseconds
* Set the GPIO pin to input mode to read data from the sensor.
.. code-block:: C
* Data Reading Loop: The loop runs up to MAXTIMINGS times to read the data bits.
For each transition (from high to low or low to high), it measures how long the pin stays in each state.
.. code-block:: C
counter = 0;
counter++;
if (counter == 255)
break;
// ... rest of the loop
* Data Bit Extraction: The first 3 transitions are ignored as they are part of the DHT11's initial response.
For each data bit, it determines if the bit is 0 or 1 based on the duration the pin stays high.
.. code-block:: C
if (counter > 16)
j++;
* Checksum Verification: After receiving all bits, the code verifies the checksum to ensure data integrity.
.. code-block:: C
* If the checksum is correct, it prints out the humidity and temperature values.
.. code-block:: C
* If the checksum fails, it prints an error message.
.. code-block:: C
else
#. Main Function:
* Prints a starting message.
.. code-block:: C
* Initializes wiringPi using BCM GPIO pin numbering.
.. code-block:: C
exit(1);
* Enters an infinite loop to read data from the DHT11 sensor every second.
.. code-block:: C
while(1)
read_dht11_dat(17);
delay(1000); // wait 1 second
