.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
2.2.1 Photoresistor
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
Photoresistor is a commonly used component of ambient light intensity in
life. It helps the controller to recognize day and night and realize
light control functions such as night lamp. This project is very similar
to potentiometer, and you might think it changing the voltage to sensing
light.
Components
.. image:: img/list_2.2.1_photoresistor.png
Principle
A photoresistor or photocell is a light-controlled variable resistor.
The resistance of a photoresistor decreases with increasing incident
light intensity; in other words, it exhibits photo conductivity. A
photoresistor can be applied in light-sensitive detector circuits, and
light- and darkness-activated switching circuits.
.. image:: img/image196.png
:width: 200
:align: center
Schematic Diagram
.. image:: img/image321.png
.. image:: img/image322.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: img/image198.png
:width: 800
**Step 2:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/2.2.1/
**Step 3:** Compile the code.
.. raw:: html
.. code-block::
gcc 2.2.1_Photoresistor.c -lwiringPi
**Step 4:** Run the executable file.
.. raw:: html
.. code-block::
The code run, the brightness of LED will vary depending on the intensity
of light that the photoresistor senses.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
**Code**
.. code-block:: c
#include
#include
#include
typedef unsigned char uchar;
typedef unsigned int uint;
#define ADC_CS 0
#define ADC_CLK 1
#define ADC_DIO 2
#define LedPin 3
uchar i;
uchar dat1=0, dat2=0;
int sel = channel > 1 & 1;
int odd = channel & 1;
digitalWrite(ADC_CLK, 1);
delayMicroseconds(2);
digitalWrite(ADC_CLK, 0);
pinMode(ADC_DIO, OUTPUT);
digitalWrite(ADC_CS, 0);
// Start bit
digitalWrite(ADC_CLK,0);
//Single End mode
// ODD
//Select
for(i=0;i<8;i++)
pinMode(ADC_DIO, INPUT);
for(i=0;i<8;i++)
dat2 = dat2 | ((uchar)(digitalRead(ADC_DIO))<
