.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! 1.3.4 Relay =========== Introduction ------------ In this lesson, we will learn to use a relay. It is one of the commonly used components in automatic control system. When the voltage, current, temperature, pressure, etc., reaches, exceeds or is lower than the predetermined value, the relay will connect or interrupt the circuit, to control and protect the equipment. Components ---------- .. image:: img/list_1.3.4.png Principle --------- **Diode** A diode is a two-terminal component in electronics with a unidirectional flow of current. It offers low resistance in the direction of current flow and offers high resistance in the opposite direction. Diodes are mostly used to prevent damage to components, especially due to electromotive force in circuits which are usually polarized. .. image:: img/image344.png The two terminals of a diode are polarized, with the positive end called anode and the negative end called cathode. The cathode is usually made of silver or has a color band. Controlling the direction of current flow is one of the key features of diodes — the current in a diode flows from anode to cathode. The behavior of a diode is similar to the behavior of a check valve. One of the most important characteristics of a diode is the non-linear current voltage. If higher voltage is connected to the anode, then current flows from anode to cathode, and the process is known as forward bias. However, if the higher voltage is connected to the cathode, then the diode does not conduct electricity, and the process is called reverse bias. **Relay** As we may know, relay is a device which is used to provide connection between two or more points or devices in response to the input signal applied. In other words, relays provide isolation between the controller and the device as devices may work on AC as well as on DC. However, they receive signals from a microcontroller which works on DC hence requiring a relay to bridge the gap. Relay is extremely useful when you need to control a large amount of current or voltage with small electrical signal. There are 5 parts in every relay: **Electromagnet** - It consists of an iron core wounded by coil of wires. When electricity is passed through, it becomes magnetic. Therefore, it is called electromagnet. **Armature** - The movable magnetic strip is known as armature. When current flows through them, the coil is it energized thus producing a magnetic field which is used to make or break the normally open (N/O) or normally close (N/C) points. And the armature can be moved with direct current (DC) as well as alternating current (AC). **Spring** - When no currents flow through the coil on the electromagnet, the spring pulls the armature away so the circuit cannot be completed. Set of electrical **contacts** - There are two contact points: - Normally open - connected when the relay is activated, and disconnected when it is inactive. - Normally close - not connected when the relay is activated, and connected when it is inactive. **Molded frame** - Relays are covered with plastic for protection. **Working of Relay** The working principle of relay is simple. When power is supplied to the relay, currents start flowing through the control coil; as a result, the electromagnet starts energizing. Then the armature is attracted to the coil, pulling down the moving contact together thus connecting with the normally open contacts. So the circuit with the load is energized. Then breaking the circuit would a similar case, as the moving contact will be pulled up to the normally closed contacts under the force of the spring. In this way, the switching on and off of the relay can control the state of a load circuit. .. image:: img/image142.jpeg Schematic Diagram ----------------- .. image:: img/image345.png Experimental Procedures ----------------------- **Step 1:** Build the circuit. .. image:: img/image144.png :width: 800 **Step 2**: Open the code file. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/c/1.3.4 **Step 3:** Compile the code. .. raw:: html .. code-block:: gcc 1.3.4_Relay.c -lwiringPi **Step 4:** Run the executable file. .. raw:: html .. code-block:: sudo ./a.out After the code runs, the LED will light up. In addition, you can hear a ticktock caused by breaking normally close contact and closing normally open contact. .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`. **Code** .. code-block:: c #include #include #define RelayPin 0 int main(void){ if(wiringPiSetup() == -1){ //when initialize wiring failed, print message to screen printf("setup wiringPi failed !"); return 1; } pinMode(RelayPin, OUTPUT); //set GPIO17(GPIO0) output while(1){ // Tick printf("Relay Open......\n"); delay(100); digitalWrite(RelayPin, LOW); delay(1000); // Tock printf("......Relay Close\n"); delay(100); digitalWrite(RelayPin, HIGH); delay(1000); } return 0; } **Code Explanation** .. code-block:: c digitalWrite(RelayPin, LOW); Set the I/O port as low level (0V), thus the transistor is not energized and the coil is not powered. There is no electromagnetic force, so the relay opens, LED does not turn on. .. code-block:: c digitalWrite(RelayPin, HIGH); set the I/O port as high level (5V) to energize the transistor. The coil of the relay is powered and generate electromagnetic force, and the relay closes, LED lights up.
