.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
1.1.1 Blinking LED
In this lesson, we will learn how to make a blinking LED by programming.
Through your settings, your LED can produce a series of interesting
phenomena. Now, go for it.
Components
.. image:: img/blinking_led_list.png
:width: 800
:align: center
.. note::
In order to proceed smoothly, you need to bring your own
Raspberry Pi, TF card and Raspberry Pi power.
Principle
**Breadboard**
A breadboard is a construction base for prototyping of electronics. It
is used to build and test circuits quickly before finishing any circuit
design. And it has many holes into which components mentioned above can
be inserted like ICs and resistors as well as jumper wires. The
breadboard allows you to plug in and remove components easily.
The picture shows the internal structure of a full+ breadboard. Although
these holes on the breadboard appear to be independent of each other,
they are actually connected to each other through metal strips
internally.
.. image:: img/image41.png
**LED**
LED is a kind of diode. LED will shine only if the long pin of LED is
connected to the positive electrode and the short pin is connected to
negative electrode.
.. |image42| image:: img/image42.png
.. |image43| image:: img/image43.png
|image42|\ |image43|
The LED can not be directly connected to power supply, which can damage
component. A resistor with 160Ω or larger (work in 5V) must be connected
in series in the circuit of LED.
**Resistor**
Resistor is an electronic element that can limit the branch current. A
fixed resistor is a kind of resistor whose resistance cannot be changed,
while that of a potentiometer or a variable resistor can be adjusted.
Fixed resistor is applied in this kit. In the circuit, it is essential
to protect the connected components. The following pictures show a real
object, 220Ω resistor and two generally used circuit symbols of
resistor. Ω is the unit of resistance and the larger units include KΩ,
MΩ, etc. Their relationship can be shown as follows: 1 MΩ=1000 KΩ, 1 KΩ
= 1000 Ω. Normally, the value of resistance is marked on it. So if you
see these symbols in a circuit, it means that there is a resistor.
.. image:: img/image44.png
.. |image45| image:: img/image45.png
.. |image46| image:: img/image46.png
|image45|\ |image46|
When using a resistor, we need to know its resistance first. Here are
two methods: you can observe the bands on the resistor, or use a
multimeter to measure the resistance. You are recommended to use the
first method as it is more convenient and faster. To measure the value,
use multimeter.
As shown in the card, each color stands for a number.
.. image:: img/image47.jpeg
Schematic Diagram
In this experiment, connect a 220Ω resistor to the anode (the long pin
of the LED), then the resistor to 3.3 V, and connect the cathode (the
short pin) of the LED to GPIO17 of Raspberry Pi. Therefore, to turn on
an LED, we need to make GPIO17 low (0V) level. We can get this
phenomenon by programming.
.. note::
**Pin11** refers to the 11th pin of the Raspberry Pi from left to right, and its corresponding **wiringPi** and **BCM** pin numbers are shown in the following table.
In the C language related content, we make GPIO0 equivalent to 0 in the
wiringPi. Among the Python language related content, BCM 17 is 17 in the
BCM column of the following table. At the same time, they are the same
as the 11th pin on the Raspberry Pi, Pin 11.
GPIO17 Pin 11 0 17
.. image:: img/image48.png
:width: 800
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: img/image49.png
:width: 800
:align: center
**Step 2:** Go to the folder of the code.
1) If you use a screen, you're recommended to take the following steps.
Go to **~/** and find the folder
**davinci-kit-for-raspberry-pi**.
Find **C** in the folder, right-click on it and select **Open in
Terminal**.
.. image:: img/image50.png
:width: 800
:align: center
Then a window will pop up as shown below. So now you've entered the path
of the code **1.1.1_BlinkingLed.c** .
.. image:: img/image51.png
:width: 800
:align: center
In the following lessons, we will use command to enter the code file
instead of right-clicking. But you can choose the method you prefer.
2) If you log into the Raspberry Pi remotely, use ``cd`` to change directory:
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/1.1.1/
.. note::
Change directory to the path of the code in this experiment via cd.
In either way, now you are in the folder C. The subsequent
procedures based on these two methods are the same. Let's move on.
**Step 3:** Compile the code
.. raw:: html
.. code-block::
gcc 1.1.1_BlinkingLed.c -o BlinkingLed -lwiringPi
.. note::
gcc is GNU Compiler Collection. Here, it functions like
compiling the C language file *1_BlinkingLed.c* and outputting an
executable file.
In the command, ``-o`` means outputting (the character immediately
following -o is the filename output after compilation, and an executable
named ``BlinkingLed`` will generate here) and ``-lwiringPi`` is to load
the library wiringPi (``l`` is the abbreviation of library).
**Step 4:** Run the executable file output in the previous step.
.. raw:: html
.. code-block::
sudo ./BlinkingLed
.. note::
To control the GPIO, you need to run the program, by the
command, sudo(superuser do). The command ``./`` indicates the current
directory. The whole command is to run the ``BlinkingLed`` in the
current directory.
.. image:: img/image52.png
:width: 800
:align: center
After the code runs, you will see the LED flashing.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
If you want to edit the code file ``1.1.1_BlinkingLed.c``, press ``Ctrl +
C`` to stop running the code. Then type the following command to open
it:
.. raw:: html
.. code-block::
nano 1.1.1_BlinkingLed.c
.. note::
nano is a text editor tool. The command is used to open the
code file ``1.1.1_BlinkingLed.c`` by this tool.
Press ``Ctrl+X`` to exit. If you have modified the code, there will be a
prompt asking whether to save the changes or not. Type in ``Y`` (save)
or ``N`` (don’t save). Then press ``Enter`` to exit. Repeat ``Step 3``
and ``Step 4`` to see the effect after modifying.
.. image:: img/image53.png
:width: 800
:align: center
**Code**
The program code is shown as follows:
.. code-block:: c
#include
#include
#define LedPin 0
int main(void)
// When initialize wiring failed, print message to screen
if(wiringPiSetup() == -1){
pinMode(LedPin, OUTPUT);// Set LedPin as output to write value to it.
// LED on
digitalWrite(LedPin, LOW);
printf("...LED on\n");
delay(500);
// LED off
digitalWrite(LedPin, HIGH);
printf("LED off...\n");
delay(500);
**Code Explanation**
.. code-block:: c
include
The hardware drive library is designed for the C language of Raspberry
Pi. Adding this library is conducive to the initialization of hardware,
and the output of I/O ports, PWM, etc.
.. code-block:: c
#include
Standard I/O library. The pintf function used for printing the data
displayed on the screen is realized by this library. There are many
other performance functions for you to explore.
.. code-block:: c
#define LedPin 0
Pin GPIO17 of the T_Extension Board is corresponding to the GPIO0 in
wiringPi. Assign GPIO0 to LedPin, LedPin represents GPIO0 in the code
later.
.. code-block:: c
This initialises wiringPi and assumes that the calling program is going
to be using the wiringPi pin numbering scheme.
This function needs to be called with root privileges.
When initialize wiring failed, print message to screen. The function
“return” is used to jump out of the current function. Using return in
main() function will end the program.
.. code-block:: c
.. code-block:: c
Set GPIO0 as 0V (low level). Since the cathode of LED is connected to
GPIO0, thus the LED will light up if GPIO0 is set low. On the contrary,
set GPIO0 as high level, digitalWrite (LedPin, HIGH): LED will go out.
.. code-block:: c
printf("...LEDÂ off\n");
The printf function is a standard library function and its function
prototype is in the header file "stdio.h". The general form of the call
is: printf(" format control string ", output table columns). The format
control string is used to specify the output format, which is divided
into format string and non-format string. The format string starts with
'%' followed by format characters, such as' %d 'for decimal integer
output. Unformatted strings are printed as prototypes. What is used here
is a non-format string, followed by "\n" that is a newline character,
representing automatic line wrapping after printing a string.
.. code-block:: c
delay(500);
Delay (500) keeps the current HIGH or LOW state for 500ms.
This is a function that suspends the program for a period of time. And
the speed of the program is determined by our hardware. Here we turn on
or off the LED. If there is no delay function, the program will run the
whole program very fast and continuously loop. So we need the delay
function to help us write and debug the program.
.. code-block:: c
Usually, it is placed behind the main function, indicating that the
function returns 0 on successful execution.
