.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
3.1.9 Password Lock
In this project, we will use a keypad and a LCD to make a combination
lock. The LCD will display a corresponding prompt for you to type your
password on the Keypad. If the password is input correctly, \"Correct\"
will be displayed.
On the basis of this project, we can add additional electronic
components, such as buzzer, LED and so on, to add different experimental
phenomena for password input.
Components
.. image:: img/list_Password_Lock.png
:align: center
Schematic Diagram
GPIO18 Pin 12 1 18
GPIO23 Pin 16 4 23
GPIO24 Pin 18 5 24
GPIO25 Pin 22 6 25
GPIO17 Pin 11 0 17
GPIO27 Pin 13 2 27
GPIO22 Pin 15 3 22
SPIMOSI Pin 19 12 10
SDA1 Pin 3
SCL1 Pin 5
.. image:: img/Schematic_three_one9.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: img/image262.png
:width: 800
**For C Language Users**
**Step 2**: Change directory.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/3.1.9/
**Step 3**: Compile.
.. raw:: html
.. code-block::
gcc 3.1.9_PasswordLock.cpp -lwiringPi
**Step 4:** Run.
.. raw:: html
.. code-block::
After the code runs, keypad is used to input password. If the \"CORRECT\"
appears on LCD1602, there is no wrong with the password; otherwise,
\"WRONG KEY\" will appear.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`.
**Code Explanation**
.. code-block:: c
#define ROWS 4
#define COLS 4
#define LENS 4
'1','2','3','A',
'4','5','6','B',
'7','8','9','C',
'*','0','#','D'};
char password[LENS]={'1','9','8','4'};
Here, we define the length of the password LENS, storage matrix keyboard
key value array KEYS and the array that stores the correct password.
.. code-block:: c
There is a declaration of the subfunctions of the matrix keyboard code,
refer to :ref:`2.1.5_keypad` of this document for more details.
.. code-block:: c
void write_word(int data);
void send_command(int comm);
void send_data(int data);
void lcdInit();
void clear();
void write(int x, int y, char const data[]);
There is a declaration of the subfunctions of LCD1062 code, refer to
:ref:`1.1.7_i2c_lcd` of this document for more details.
.. code-block:: c
keyRead(pressed_keys);
testword[keyIndex]=pressed_keys[0];
keyIndex++;
if(keyIndex==LENS){
if(check()==0){
clear();
write(3, 0, "WRONG KEY!");
write(0, 1, "please try again");
Read the key value and store it in the test array testword. If the
number of stored key values is more than 4, the correctness of the
password is automatically verified, and the verification results are
displayed on the LCD interface.
.. code-block:: c
int check(){
for(int i=0;i
.. code-block::
**Step 3:** Run.
.. raw:: html
.. code-block::
sudo python3 3.1.9_PasswordLock.py
After the code runs, keypad is used to input password:1984. If the
\"CORRECT\" appears on LCD1602, there is no wrong with the password;
otherwise, \"WRONG KEY\" will appear.
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``.
.. raw:: html
.. code-block:: python
import RPi.GPIO as GPIO
import LCD1602
##################### HERE IS THE KEYPAD LIBRARY TRANSPLANTED FROM Arduino ############
#class Key:Define some of the properties of Key
class Keypad():
def __init__(self, rowsPins, colsPins, keys):
self.rowsPins = rowsPins
self.colsPins = colsPins
self.keys = keys
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
GPIO.setup(self.rowsPins, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(self.colsPins, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
def read(self):
pressed_keys = []
for i, row in enumerate(self.rowsPins):
GPIO.output(row, GPIO.HIGH)
for j, col in enumerate(self.colsPins):
index = i * len(self.colsPins) + j
if (GPIO.input(col) == 1):
GPIO.output(row, GPIO.LOW)
return pressed_keys
################ EXAMPLE CODE START HERE ################
LENS = 4
password=['1','9','8','4']
testword=['0','0','0','0']
keyIndex=0
def check():
for i in range(0,LENS):
if(password[i]!=testword[i]):
return 0
return 1
def setup():
global keypad, last_key_pressed
rowsPins = [18,23,24,25]
colsPins = [10,22,27,17]
keys = ["1","2","3","A",
"4","5","6","B",
"7","8","9","C",
"*","0","#","D"]
keypad = Keypad(rowsPins, colsPins, keys)
last_key_pressed = []
LCD1602.init(0x27, 1) # init(slave address, background light)
LCD1602.clear()
LCD1602.write(0, 0, 'WELCOME!')
LCD1602.write(2, 1, 'Enter password')
time.sleep(2)
def destroy():
LCD1602.clear()
GPIO.cleanup()
def loop():
global keyIndex
global LENS
while(True):
pressed_keys = keypad.read()
if len(pressed_keys) != 0 and last_key_pressed != pressed_keys:
LCD1602.clear()
LCD1602.write(0, 0, "Enter password:")
LCD1602.write(15-keyIndex,1, pressed_keys)
keyIndex+=1
if (keyIndex is LENS):
if (check() is 0):
LCD1602.clear()
LCD1602.write(3, 0, "WRONG KEY!")
LCD1602.write(0, 1, "please try again")
LCD1602.clear()
LCD1602.write(4, 0, "CORRECT!")
LCD1602.write(2, 1, "welcome back")
keyIndex=keyIndex%LENS
time.sleep(0.1)
setup()
loop()
destroy()
LENS = 4
"4","5","6","B",
"7","8","9","C",
"*","0","#","D"]
Here, we define the length of the password LENS, the array keys that
store the matrix keyboard keys, and the array password that stores the
correct password.
class Keypad():
self.keys = keys
This class is the code that reads the values of the pressed keys. Refer
while(True):
LCD1602.clear()
keyIndex+=1
def check():
return 0
return 1
Verify the correctness of the password. Return 1 if the password is
entered correctly, and 0 if not.
Phenomenon Picture
.. image:: img/image263.jpeg
:align: center
