.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! 3.1.6 Motion Control ====================== Introduction ----------------- In this lesson, we will make a simple motion sensing and controlling device. The MPU6050 is used as a sensor and the stepper motor as a controlled device. With the MPU6050 mounted on the glove, you can control the stepper motor by rotating your wrist. Components --------------- .. image:: img/list_Motion_Control.png :align: center Schematic Diagram -------------------------- ============ ======== ======== === T-Board Name physical wiringPi BCM GPIO18 Pin 12 1 18 GPIO23 Pin 16 4 23 GPIO24 Pin 18 5 24 GPIO25 Pin 22 6 25 SDA1 Pin 3 SCL1 Pin 5 ============ ======== ======== === .. image:: img/Schematic_three_one6.png :align: center Experimental Procedures ------------------------------ **Step 1:** Build the circuit. .. image:: img/image251.png :width: 800 :align: center **For C Language Users** ^^^^^^^^^^^^^^^^^^^^^^^^^^ **Step 2**: Go to the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/c/3.1.6/ **Step 3**: Compile the code. .. raw:: html .. code-block:: gcc 3.1.6_MotionControl.c -lwiringPi -lm **Step 4**: Run the executable file. .. raw:: html .. code-block:: sudo ./a.out As the code runs, if the tilt angle of **mpu6050** on the `Y `__-`axis `__ is larger than **45** ℃, the stepper motor rotates anticlockwise; if less than **-45** ℃, the stepper motor rotates clockwise. .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`. **Code Explanation** .. code-block:: c double mpu6050(){     acclX = read_word_2c(0x3B);     acclY = read_word_2c(0x3D);     acclZ = read_word_2c(0x3F);     acclX_scaled = acclX / 16384.0;     acclY_scaled = acclY / 16384.0;     acclZ_scaled = acclZ / 16384.0;     double angle=get_y_rotation(acclX_scaled, acclY_scaled, acclZ_scaled);     return angle; } mpu6050 gets the tilt angle in the direction of the Y-axis. .. code-block:: c void rotary(char direction){     if(direction == 'c'){         for(int j=0;j<4;j++){             for(int i=0;i<4;i++)                 {digitalWrite(motorPin[i],0x99>>j & (0x08>>i));}             delayMicroseconds(stepSpeed);         }             }     else if(direction =='a'){         for(int j=0;j<4;j++){             for(int i=0;i<4;i++)                 {digitalWrite(motorPin[i],0x99<>i));}             delayMicroseconds(stepSpeed);         }        } } If the received direction **key** is \'**c**\', the stepper motor rotates clockwise; if the **key** is \'**a**\', the motor rotates anticlockwise. Refer to :ref:`1.3.3_stepper` for more details about the calculation of the rotating direction of the stepper motor. .. code-block:: c int main() {     setup();     double angle;     while(1) {         angle = mpu6050();         if (angle >=45){rotary('a');}         else if (angle<=-45){rotary('c');}     }     return 0; } The tilt angle in the direction of the Y-axis is read from **mpu6050**, and if it’s larger than **45** ℃, the stepper motor rotates anticlockwise; if less than **-45** ℃, the stepper motor rotates clockwise. **For Python Language Users** ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ **Step 2**: Go to the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/python/ **Step 3**: Run the executable file. .. raw:: html .. code-block:: sudo python3 3.1.6_MotionControl.py As the code runs, if the tilt angle of **mpu6050** on the `Y `__\ **-**\ `axis `__ is larger than **45** ℃, the stepper motor rotates anticlockwise; if less than **-45** ℃, the stepper motor rotates clockwise. **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``. .. raw:: html .. code-block:: python import RPi.GPIO as GPIO import smbus import math import time # Power management registers power_mgmt_1 = 0x6b power_mgmt_2 = 0x6c bus = smbus.SMBus(1) address = 0x68 bus.write_byte_data(address, power_mgmt_1, 0) #Stepper motor pins motorPin = (18,23,24,25) rolePerMinute =15 stepsPerRevolution = 2048 stepSpeed = (60/rolePerMinute)/stepsPerRevolution #mpu6050 def read_byte(adr): return bus.read_byte_data(address, adr) def read_word(adr): high = bus.read_byte_data(address, adr) low = bus.read_byte_data(address, adr+1) val = (high << 8) + low return val def read_word_2c(adr): val = read_word(adr) if (val >= 0x8000): return -((65535 - val) + 1) else: return val def dist(a,b): return math.sqrt((a*a)+(b*b)) def get_y_rotation(x,y,z): radians = math.atan2(x, dist(y,z)) return -math.degrees(radians) def get_x_rotation(x,y,z): radians = math.atan2(y, dist(x,z)) return math.degrees(radians) def mpu6050(): accel_xout = read_word_2c(0x3b) accel_yout = read_word_2c(0x3d) accel_zout = read_word_2c(0x3f) accel_xout_scaled = accel_xout / 16384.0 accel_yout_scaled = accel_yout / 16384.0 accel_zout_scaled = accel_zout / 16384.0 angle=get_y_rotation(accel_xout_scaled, accel_yout_scaled, accel_zout_scaled) return angle #Stepper Motor def rotary(direction): if(direction == 'c'): for j in range(4): for i in range(4): GPIO.output(motorPin[i],0x99>>j & (0x08>>i)) time.sleep(stepSpeed) elif(direction == 'a'): for j in range(4): for i in range(4): GPIO.output(motorPin[i],0x99<>i)) time.sleep(stepSpeed) def setup(): GPIO.setwarnings(False) GPIO.setmode(GPIO.BCM) for i in motorPin: GPIO.setup(i, GPIO.OUT) def loop(): while True: angle=mpu6050() if angle >=45 : rotary('a') elif angle <=-45: rotary('c') def destroy(): GPIO.cleanup() if __name__ == '__main__': setup() try: loop() except KeyboardInterrupt: destroy() **Code Explanation** .. code-block:: python def mpu6050():     accel_xout = read_word_2c(0x3b)     accel_yout = read_word_2c(0x3d)     accel_zout = read_word_2c(0x3f)     accel_xout_scaled = accel_xout / 16384.0     accel_yout_scaled = accel_yout / 16384.0     accel_zout_scaled = accel_zout / 16384.0     angle=get_y_rotation(accel_xout_scaled, accel_yout_scaled, accel_zout_scaled)     return angle mpu6050 gets the tilt angle in the direction of the Y-axis. .. code-block:: python def rotary(direction):     if(direction == 'c'):            for j in range(4):             for i in range(4):                 GPIO.output(motorPin[i],0x99>>j & (0x08>>i))             time.sleep(stepSpeed)     elif(direction == 'a'):         for j in range(4):             for i in range(4):                 GPIO.output(motorPin[i],0x99<>i))             time.sleep(stepSpeed) If the received direction **key** is \'**c**\', the stepper motor rotates clockwise; if the **key** is \'**a**\', the motor rotates anticlockwise. Refer to :ref:`1.3.3_stepper` for more details about the calculation of the rotating direction of the stepper motor. .. code-block:: python def loop():     while True:         angle=mpu6050()         if angle >=45 :             rotary('a')         elif angle <=-45:             rotary('c') The tilt angle in the direction of the **Y-axis** is read from **mpu6050**, and if it’s larger than **45** ℃, rotary() is called to let the stepper motor rotate anticlockwise; if less than **-45** ℃, the stepper motor rotates clockwise. Phenomenon Picture ----------------------- .. image:: img/image252.jpeg :align: center
