.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! 3.1.4 Smart Fan ================= .. note:: .. image:: img/mcp3008_and_adc0834.jpg :width: 25% :align: left Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section. Introduction ----------------- In this course, we will use motors, buttons and thermistors to make a manual + automatic smart fan whose wind speed is adjustable. Components ------------------ .. image:: img/list_Smart_Fan.png :align: center Schematic Diagram ------------------------ ============ ======== ======== === T-Board Name physical wiringPi BCM GPIO17 Pin 11 0 17 GPIO18 Pin 12 1 18 GPIO27 Pin 13 2 27 GPIO22 Pin 15 3 22 GPIO5 Pin 29 21 5 GPIO6 Pin 31 22 6 GPIO13 Pin 33 23 13 ============ ======== ======== === .. image:: img/Schematic_three_one4.png :width: 500 :align: center Experimental Procedures ----------------------------- **Step 1:** Build the circuit. .. image:: img/image245.png :width: 800 :align: center .. note:: The power module can apply a 9V battery with the 9V Battery Buckle in the kit. Insert the jumper cap of the power module into the 5V bus strips of the breadboard. .. image:: img/image118.jpeg :width: 2.80694in :height: 0.94375in :align: center **For C Language Users** ^^^^^^^^^^^^^^^^^^^^^^^^^ **Step 2**: Get into the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/c/3.1.4/ **Step 3**: Compile. .. raw:: html .. code-block:: gcc 3.1.4_SmartFan.c -lwiringPi -lm **Step 4**: Run the executable file above. .. raw:: html .. code-block:: sudo ./a.out As the code runs, start the fan by pressing the button. Every time you press, 1 speed grade is adjusted up or down. There are **5** kinds of speed grades: **0~4**. When set to the 4\ :sup:`th` speed grade and you press the button, the fan stops working with a **0** wind speed. .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`. Once the temperature goes up or down for more than 2℃, the speed automatically gets 1-grade faster or slower. **Code Explanation** .. code-block:: c int temperture(){     unsigned char analogVal;     double Vr, Rt, temp, cel, Fah;     analogVal = get_ADC_Result(0);     Vr = 5 * (double)(analogVal) / 255;     Rt = 10000 * (double)(Vr) / (5 - (double)(Vr));     temp = 1 / (((log(Rt/10000)) / 3950)+(1 / (273.15 + 25)));     cel = temp - 273.15;     Fah = cel * 1.8 +32;     int t=cel;     return t; } Temperture() works by converting thermistor values read by ADC0834 into temperature values. Refer to :ref:`2.2.2_thermistor` for more details. .. code-block:: c int motor(int level){     if(level==0){         digitalWrite(MotorEnable,LOW);         return 0;     }     if (level>=4){         level =4;     }     digitalWrite(MotorEnable,HIGH);     softPwmWrite(MotorPin1, level*25);     return level;     } This function controls the rotating speed of the motor. The range of the **Level**: **0-4** (level **0** stops the working motor). One level adjustment stands for a **25%** change of the wind speed. .. code-block:: c int main(void) {     setup();     int currentState,lastState=0;     int level = 0;     int currentTemp,markTemp=0;     while(1){         currentState=digitalRead(BtnPin);         currentTemp=temperture();         if (currentTemp<=0){continue;}         if (currentState==1&&lastState==0){             level=(level+1)%5;             markTemp=currentTemp;             delay(500);         }         lastState=currentState;         if (level!=0){             if (currentTemp-markTemp<=-2){                 level=level-1;                 markTemp=currentTemp;             }             if (currentTemp-markTemp>=2){                 level=level+1;                 markTemp=currentTemp;             }         }         level=motor(level);     }     return 0; } The function **main()** contains the whole program process as shown: 1) Constantly read the button state and the current temperature. 2) Every press makes level\ **+1** and at the same time, the temperature is updated. The **Level** ranges **1~4**. 3) As the fan works ( the level is **not 0**), the temperature is under detection. A **2℃\ +** change causes the up and down of the level. 4) The motor changes the rotating speed with the **Level**. **For Python Language Users** ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ **Step 2**: Get into the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/python **Step 3**: Run. .. raw:: html .. code-block:: sudo python3 3.1.4_SmartFan.py As the code runs, start the fan by pressing the button. Every time you press, 1 speed grade is adjusted up or down. There are **5** kinds of speed grades: **0~4**. When set to the 4\ :sup:`th` speed grade and you press the button, the fan stops working with a **0** wind speed. Once the temperature goes up or down for more than 2℃, the speed automatically gets 1-grade faster or slower. **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``. .. raw:: html .. code-block:: python import RPi.GPIO as GPIO import time import ADC0834 import math # Set up pins MotorPin1 = 5 MotorPin2 = 6 MotorEnable = 13 BtnPin = 22 def setup(): global p_M1,p_M2 ADC0834.setup() GPIO.setmode(GPIO.BCM) GPIO.setup(MotorPin1, GPIO.OUT) GPIO.setup(MotorPin2, GPIO.OUT) p_M1=GPIO.PWM(MotorPin1,2000) p_M2=GPIO.PWM(MotorPin2,2000) p_M1.start(0) p_M2.start(0) GPIO.setup(MotorEnable, GPIO.OUT, initial=GPIO.LOW) GPIO.setup(BtnPin, GPIO.IN) def temperature(): analogVal = ADC0834.getResult() Vr = 5 * float(analogVal) / 255 Rt = 10000 * Vr / (5 - Vr) temp = 1/(((math.log(Rt / 10000)) / 3950) + (1 / (273.15+25))) Cel = temp - 273.15 Fah = Cel * 1.8 + 32 return Cel def motor(level): if level == 0: GPIO.output(MotorEnable, GPIO.LOW) return 0 if level>=4: level = 4 GPIO.output(MotorEnable, GPIO.HIGH) p_M1.ChangeDutyCycle(level*25) return level def main(): lastState=0 level=0 markTemp = temperature() while True: currentState =GPIO.input(BtnPin) currentTemp=temperature() if currentState == 1 and lastState == 0: level=(level+1)%5 markTemp = currentTemp time.sleep(0.5) lastState=currentState if level!=0: if currentTemp-markTemp <= -2: level = level -1 markTemp=currentTemp if currentTemp-markTemp >= 2: level = level +1 markTemp=currentTemp level = motor(level) def destroy(): GPIO.output(MotorEnable, GPIO.LOW) p_M1.stop() p_M2.stop() GPIO.cleanup() if __name__ == '__main__': setup() try: main() except KeyboardInterrupt: destroy() **Code Explanation** .. code-block:: python def temperature():     analogVal = ADC0834.getResult()     Vr = 5 * float(analogVal) / 255     Rt = 10000 * Vr / (5 - Vr)     temp = 1/(((math.log(Rt / 10000)) / 3950) + (1 / (273.15+25)))     Cel = temp - 273.15     Fah = Cel * 1.8 + 32     return Cel temperture() works by converting thermistor values read by **ADC0834** into temperature values. Refer to :ref:`2.2.2_thermistor` for more details. .. code-block:: python def motor(level):     if level == 0:         GPIO.output(MotorEnable, GPIO.LOW)         return 0     if level>=4:         level = 4     GPIO.output(MotorEnable, GPIO.HIGH)     p_M1.ChangeDutyCycle(level*25)     return level This function controls the rotating speed of the motor. The range of the **Lever**: **0-4** (level **0** stops the working motor). One level adjustment stands for a **25%** change of the wind speed. .. code-block:: python def main():     lastState=0     level=0     markTemp = temperature()     while True:         currentState =GPIO.input(BtnPin)         currentTemp=temperature()         if currentState == 1 and lastState == 0:             level=(level+1)%5             markTemp = currentTemp             time.sleep(0.5)         lastState=currentState         if level!=0:             if currentTemp-markTemp <= -2:                 level = level -1                 markTemp=currentTemp                         if currentTemp-markTemp >= 2:                 level = level +1                 markTemp=currentTemp                      level = motor(level) The function **main()** contains the whole program process as shown: 1) Constantly read the button state and the current temperature. 2) Every press makes level\ **+1** and at the same time, the temperature is updated. The **Level** ranges **1~4**. 3) As the fan works ( the level is **not 0**), the temperature is under detection. A **2℃\ +** change causes the up and down of the level. 4) The motor changes the rotating speed with the **Level**. Phenomenon Picture ------------------------ .. image:: img/image246.png :align: center
