.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! 3.1.2 Welcome =============== Introduction ------------- In this project, we will use PIR to sense the movement of pedestrians, and use servos, LED, buzzer to simulate the work of the sensor door of the convenience store. When the pedestrian appears within the sensing range of the PIR, the indicator light will be on, the door will be opened, and the buzzer will play the opening bell. Components --------------- .. image:: img/list_Welcome.png :align: center Schematic Diagram ------------------- ============ ======== ======== === T-Board Name physical wiringPi BCM GPIO18 Pin 12 1 18 GPIO17 Pin 11 0 17 GPIO27 Pin 13 2 27 GPIO22 Pin 15 3 22 ============ ======== ======== === .. image:: img/Schematic_three_one2.png :align: center Experimental Procedures ------------------------- **Step 1:** Build the circuit. .. image:: img/image239.png :width: 800 :align: center **For C Language Users** ^^^^^^^^^^^^^^^^^^^^^^^^^^ **Step 2:** Change directory. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/c/3.1.2/ **Step 3:** Compile. .. raw:: html .. code-block:: gcc 3.1.2_Welcome.c -lwiringPi **Step 4:** Run. .. raw:: html .. code-block:: sudo ./a.out After the code runs, if the PIR sensor detects someone passing by, the door will automatically open (simulated by the servo), turn on the indicator and play the doorbell music. After the doorbell music plays, the system will automatically close the door and turn off the indicator light, waiting for the next time someone passes by. There are two potentiometers on the PIR module: one is to adjust sensitivity and the other is to adjust the detection distance. To make the PIR module work better, you You need to turn both of them counterclockwise to the end. .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`. **Code Explanation** .. code-block:: c void setAngle(int pin, int angle){ //Create a funtion to control the angle of the servo. if(angle < 0) angle = 0; if(angle > 180) angle = 180; softPwmWrite(pin,Map(angle, 0, 180, 5, 25)); } Create a function, setAngle to write the angle in the servo that is 0-180. .. code-block:: c void doorbell(){ for(int i=0;i-1;i--){ //make servo rotate from maximum angle to minimum angle setAngle(servoPin,i); delay(1); } } Create a closedoor function to simulate closing the door, turn off the LED and let the servo turn from 180 degrees to 0 degree. .. code-block:: c void opendoor(){ digitalWrite(ledPin, HIGH); //led on for(int i=0;i<181;i++){ //make servo rotate from minimum angle to maximum angle setAngle(servoPin,i); delay(1); } doorbell(); closedoor(); } The function opendoor() includes several parts: turn on the indicator light, turn the servo (simulate the action of opening the door), play the doorbell music of the convenience store, and call the function closedoor() after playing music. .. code-block:: c int main(void) { if(wiringPiSetup() == -1){ //when initialize wiring failed,print message to screen printf("setup wiringPi failed !"); return 1; } if(softToneCreate(BuzPin) == -1){ printf("setup softTone failed !"); return 1; ...... In the function main(), initialize library wiringPi and setup softTone, then set ledPin to output state and pirPin to input state. If the PIR sensor detects someone passing by, the function opendoor will be called to simulate opening the door. **For Python Language Users** ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ **Step 2:** Change directory. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/python/ **Step 3:** Run. .. raw:: html .. code-block:: sudo python3 3.1.2_Welcome.py After the code runs, if the PIR sensor detects someone passing by, the door will automatically open (simulated by the servo), turn on the indicator and play the doorbell music. After the doorbell music plays, the system will automatically close the door and turn off the indicator light, waiting for the next time someone passes by. There are two potentiometers on the PIR module: one is to adjust sensitivity and the other is to adjust the detection distance. To make the PIR module work better, you You need to turn both of them counterclockwise to the end. **code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``. .. raw:: html .. code-block:: python import RPi.GPIO as GPIO import time SERVO_MIN_PULSE = 500 SERVO_MAX_PULSE = 2500 ledPin = 18 # define the ledPin pirPin = 17 # define the sensorPin servoPin = 22 # define the servoPin buzPin = 27 # define the buzzerpin CL = [0, 131, 147, 165, 175, 196, 211, 248] # Frequency of Low C notes CM = [0, 262, 294, 330, 350, 393, 441, 495] # Frequency of Middle C notes CH = [0, 525, 589, 661, 700, 786, 882, 990] # Frequency of High C notes song = [ CH[5],CH[2],CM[6],CH[2],CH[3],CH[6],CH[3],CH[5],CH[3],CM[6],CH[2] ] beat = [ 1,1,1,1,1,2,1,1,1,1,1,] def setup(): global p global Buzz # Assign a global variable to replace GPIO.PWM GPIO.setmode(GPIO.BCM) # Numbers GPIOs by physical location GPIO.setup(ledPin, GPIO.OUT) # Set ledPin's mode is output GPIO.setup(pirPin, GPIO.IN) # Set sensorPin's mode is input GPIO.setup(servoPin, GPIO.OUT) # Set servoPin's mode is output GPIO.output(servoPin, GPIO.LOW) # Set servoPin to low GPIO.setup(buzPin, GPIO.OUT) # Set pins' mode is output Buzz = GPIO.PWM(buzPin, 440) # 440 is initial frequency. Buzz.start(50) # Start Buzzer pin with 50% duty ration p = GPIO.PWM(servoPin, 50) # set Frequece to 50Hz p.start(0) # Duty Cycle = 0 def map(value, inMin, inMax, outMin, outMax): return (outMax - outMin) * (value - inMin) / (inMax - inMin) + outMin def setAngle(angle): # make the servo rotate to specific angle (0-180 degrees) angle = max(0, min(180, angle)) pulse_width = map(angle, 0, 180, SERVO_MIN_PULSE, SERVO_MAX_PULSE) pwm = map(pulse_width, 0, 20000, 0, 100) p.ChangeDutyCycle(pwm)#map the angle to duty cycle and output it def doorbell(): for i in range(1, len(song)): # Play song 1 Buzz.ChangeFrequency(song[i]) # Change the frequency along the song note time.sleep(beat[i] * 0.25) # delay a note for beat * 0.25s time.sleep(1) # Wait a second for next song. def closedoor(): GPIO.output(ledPin, GPIO.LOW) for i in range(180, -1, -1): #make servo rotate from 180 to 0 deg setAngle(i) time.sleep(0.001) time.sleep(1) def opendoor(): GPIO.output(ledPin, GPIO.LOW) for i in range(0, 181, 1): #make servo rotate from 0 to 180 deg setAngle(i) # Write to servo time.sleep(0.001) time.sleep(1) doorbell() closedoor() def loop(): while True: if GPIO.input(pirPin)==GPIO.HIGH: opendoor() def destroy(): GPIO.cleanup() # Release resource p.stop() Buzz.stop() if __name__ == '__main__': # Program start from here setup() try: loop() except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the program destroy() will be executed. destroy() **Code Explanation** .. code-block:: python def setup(): global p global Buzz # Assign a global variable to replace GPIO.PWM GPIO.setmode(GPIO.BCM) # Numbers GPIOs by physical location GPIO.setup(ledPin, GPIO.OUT) # Set ledPin's mode is output GPIO.setup(pirPin, GPIO.IN) # Set sensorPin's mode is input GPIO.setup(buzPin, GPIO.OUT) # Set pins' mode is output Buzz = GPIO.PWM(buzPin, 440) # 440 is initial frequency. Buzz.start(50) # Start Buzzer pin with 50% duty ration GPIO.setup(servoPin, GPIO.OUT) # Set servoPin's mode is output GPIO.output(servoPin, GPIO.LOW) # Set servoPin to low p = GPIO.PWM(servoPin, 50) # set Frequece to 50Hz p.start(0) # Duty Cycle = 0 These statements are used to initialize the pins of each component. .. code-block:: python def setAngle(angle): # make the servo rotate to specific angle (0-180 degrees) angle = max(0, min(180, angle)) pulse_width = map(angle, 0, 180, SERVO_MIN_PULSE, SERVO_MAX_PULSE) pwm = map(pulse_width, 0, 20000, 0, 100) p.ChangeDutyCycle(pwm)#map the angle to duty cycle and output it Create a function, servowrite to write the angle in the servo that is 0-180. .. code-block:: python def doorbell(): for i in range(1,len(song)): # Play song1 Buzz.ChangeFrequency(song[i]) # Change the frequency along the song note time.sleep(beat[i] * 0.25) # delay a note for beat * 0.25s Create a function, doorbell to enable the buzzer to play music. .. code-block:: python def closedoor(): GPIO.output(ledPin, GPIO.LOW) Buzz.ChangeFrequency(1) for i in range(180, -1, -1): #make servo rotate from 180 to 0 deg setAngle(i) time.sleep(0.001) Close the door and turn off the indicator light. .. code-block:: python def opendoor(): GPIO.output(ledPin, GPIO.LOW) for i in range(0, 181, 1): #make servo rotate from 0 to 180 deg setAngle(i) # Write to servo time.sleep(0.001) doorbell() closedoor() The function, opendoor() consists of several parts: turn on the indicator light, turn the servo (to simulate the action of opening the door), play the doorbell music of the convenience store, and call the function , closedoor() after playing music. .. code-block:: python def loop(): while True: if GPIO.input(pirPin)==GPIO.HIGH: opendoor() When PIR senses that someone is passing by, it calls the function, opendoor(). Phenomenon Picture -------------------- .. image:: img/image240.jpeg :align: center
