.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
3.1.13 GAME– 10 Second
Next, follow me to make a game device to challenge your concentration.
Tie the tilt switch to a stick to make a magic wand. Shake the wand, the
4-digit segment display will start counting, shake again will let it
stop counting. If you succeed in keeping the displayed count at
**10.00**, then you win. You can play the game with your friends to see
who is the time wizard.
Components
.. image:: img/list_GAME_10_Second.png
:align: center
Schematic Diagram
GPIO17 Pin 11 0 17
GPIO27 Pin 13 2 27
GPIO22 Pin 15 3 22
SPIMOSI Pin 19 12 10
GPIO18 Pin 12 1 18
GPIO23 Pin 16 4 23
GPIO24 Pin 18 5 24
GPIO26 Pin 37 25 26
.. image:: img/Schematic_three_one13.png
:align: center
Experimental Procedures
**Step 1**: Build the circuit.
.. image:: img/image277.png
:width: 800
**For C Language Users**
**Step 2**: Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/3.1.13/
**Step 3**: Compile the code.
.. raw:: html
.. code-block::
gcc 3.1.13_GAME_10Second.c -lwiringPi
**Step 4**: Run the executable file.
.. raw:: html
.. code-block::
Shake the wand, the 4-digit segment display will start counting, shake
again will let it stop counting. If you succeed in keeping the displayed
count at **10.00**, then you win. Shake it one more time to start the
next round of the game.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`.
**Code Explanation**
.. code-block:: c
void stateChange(){
if (gameState == 0){
counter = 0;
delay(1000);
ualarm(10000,10000);
}else{
alarm(0);
delay(1000);
gameState = (gameState + 1)%2;
The game is divided into two modes:
gameState=0 is the \"start\" mode, in which the time is timed and
displayed on the segment display, and the tilting switch is shaken to
enter the \"show\" mode.
GameState =1 is the \"show\" mode, which stops the timing and displays the
time on the segment display. Shaking the tilt switch again will reset
the timer and restart the game.
.. code-block:: c
void loop(){
int currentState =0;
int lastState=0;
display();
currentState=digitalRead(sensorPin);
if((currentState==0)&&(lastState==1)){
stateChange();
lastState=currentState;
Loop() is the main function. First, the time is displayed on the 4-bit
segment display and the value of the tilt switch is read. If the state
of the tilt switch has changed, stateChange() is called.
**For Python Language Users**
.. raw:: html
.. code-block::
**Step 3**: Run the executable file.
.. raw:: html
.. code-block::
sudo python3 3.1.13_GAME_10Second.py
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``.
.. raw:: html
.. code-block:: python
import RPi.GPIO as GPIO
import threading
sensorPin = 26
SDI = 24
RCLK = 23
SRCLK = 18
placePin = (10, 22, 27, 17)
counter = 0
timer =0
gameState =0
def clearDisplay():
for i in range(8):
GPIO.output(SDI, 1)
GPIO.output(SRCLK, GPIO.HIGH)
GPIO.output(SRCLK, GPIO.LOW)
GPIO.output(RCLK, GPIO.HIGH)
GPIO.output(RCLK, GPIO.LOW)
def hc595_shift(data):
for i in range(8):
GPIO.output(SDI, 0x80 & (data << i))
def pickDigit(digit):
for i in placePin:
GPIO.output(i,GPIO.LOW)
GPIO.output(placePin[digit], GPIO.HIGH)
def display():
global counter
clearDisplay()
pickDigit(0)
clearDisplay()
pickDigit(1)
hc595_shift(number[counter % 100//10])
clearDisplay()
pickDigit(2)
hc595_shift(number[counter % 1000//100]-0x80)
clearDisplay()
pickDigit(3)
hc595_shift(number[counter % 10000//1000])
def stateChange():
global gameState
global counter
global timer1
if gameState == 0:
counter = 0
time.sleep(1)
timer()
elif gameState ==1:
timer1.cancel()
time.sleep(1)
gameState = (gameState+1)%2
def loop():
global counter
currentState = 0
lastState = 0
display()
currentState=GPIO.input(sensorPin)
stateChange()
def timer():
global counter
global timer1
timer1 = threading.Timer(0.01, timer)
timer1.start()
counter += 1
def setup():
GPIO.setmode(GPIO.BCM)
GPIO.setup(SDI, GPIO.OUT)
GPIO.setup(RCLK, GPIO.OUT)
GPIO.setup(SRCLK, GPIO.OUT)
for i in placePin:
GPIO.setup(i, GPIO.OUT)
GPIO.setup(sensorPin, GPIO.IN)
def destroy(): # When \"Ctrl+C\" is pressed, the function is executed.
GPIO.cleanup()
global timer1
timer1.cancel()
if __name__ == '__main__': # Program starting from here
setup()
loop()
destroy()
def stateChange():
global gameState
global counter
global timer1
if gameState == 0:
counter = 0
time.sleep(1)
timer()
elif gameState ==1:
timer1.cancel()
time.sleep(1)
def loop():
global counter
currentState = 0
lastState = 0
display()
stateChange()
def timer():
global counter
global timer1
timer1.start()
counter += 1
After the interval reaches 0.01s, the timer function is called; add 1 to
counter, and the timer is used again to execute itself repeatedly every
0.01s.
Phenomenon Picture
.. image:: img/image278.jpeg
:align: center
