.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
2.1.6 Joystick
.. note::
.. image:: img/mcp3008_and_adc0834.jpg
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
In this project, We're going to learn how joystick works. We manipulate
the Joystick and display the results on the screen.
Components
.. image:: img/image317.png
Principle
**Joystick**
The basic idea of a joystick is to translate the movement of a stick
into electronic information that a computer can process.
In order to communicate a full range of motion to the computer, a
joystick needs to measure the stick's position on two axes -- the X-axis
(left to right) and the Y-axis (up and down). Just as in basic geometry,
the X-Y coordinates pinpoint the stick's position exactly.
To determine the location of the stick, the joystick control system
simply monitors the position of each shaft. The conventional analog
joystick design does this with two potentiometers, or variable
resistors.
The joystick also has a digital input that is actuated when the joystick
is pressed down.
.. image:: img/image318.png
Schematic Diagram
When the data of joystick is read, there are some differents between
axis: data of X and Y axis is analog, which need to use ADC0834 to
convert the analog value to digital value. Data of Z axis is digital, so
you can directly use the GPIO to read, or you can also use ADC to read.
.. image:: img/image319.png
.. image:: img/image320.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: img/image193.png
:width: 800
For C Language Users
**Step 2:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/2.1.6/
**Step 3:** Compile the code.
.. raw:: html
.. code-block::
gcc 2.1.6_Joystick.c -lwiringPi
**Step 4:** Run the executable file.
.. raw:: html
.. code-block::
After the code runs, turn the Joystick, then the corresponding values of
x, y, Btn are displayed on screen.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`.
**Code**
.. code-block:: c
#include
#include
#include
typedef unsigned char uchar;
typedef unsigned int uint;
#define ADC_CS 0
#define ADC_CLK 1
#define ADC_DIO 2
#define BtnPin 3
uchar i;
uchar dat1=0, dat2=0;
int sel = channel > 1 & 1;
int odd = channel & 1;
digitalWrite(ADC_CLK, 1);
delayMicroseconds(2);
digitalWrite(ADC_CLK, 0);
pinMode(ADC_DIO, OUTPUT);
digitalWrite(ADC_CS, 0);
// Start bit
digitalWrite(ADC_CLK,0);
//Single End mode
// ODD
//Select
for(i=0;i<8;i++)
pinMode(ADC_DIO, INPUT);
for(i=0;i<8;i++)
dat2 = dat2 | ((uchar)(digitalRead(ADC_DIO))< 1 & 1;
// Start bit
//Single End mode
The working process of the function is detailed in 2.1.4 Potentiometer.
.. code-block:: c
x_val = get_ADC_Result(0);
y_val = get_ADC_Result(1);
btn_val = digitalRead(BtnPin);
printf("x = %d, y = %d, btn = %d\n", x_val, y_val, btn_val);
delay(100);
VRX and VRY of Joystick are connected to CH0, CH1 of ADC0834
respectively. So the function getResult() is called to read the values
of CH0 and CH1. Then the read values should be stored in the variables
x_val and y_val. In addition, read the value of SW of joystick and store
it into the variable Btn_val. Finally, the values of x_val, y_val and
Btn_val shall be printed with print() function.
For Python Language Users
.. raw:: html
.. code-block::
**Step 3:** Run.
.. raw:: html
.. code-block::
sudo python3 2.1.6_Joystick.py
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``.
.. raw:: html
.. code-block:: python
import RPi.GPIO as GPIO
import ADC0834
BtnPin = 22
def setup():
GPIO.setmode(GPIO.BCM)
GPIO.setup(BtnPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
ADC0834.setup()
def destroy():
# Release resource
GPIO.cleanup()
def loop():
x_val = ADC0834.getResult(0)
y_val = ADC0834.getResult(1)
Btn_val = GPIO.input(BtnPin)
print ('X: %d Y: %d Btn: %d' % (x_val, y_val, Btn_val))
time.sleep(0.2)
if __name__ == '__main__':
setup()
loop()
destroy()
**Code Explanation**
def loop():
time.sleep(0.2)
Phenomenon Picture
.. image:: img/image194.jpeg
