.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _2.1.5_keypad: 2.1.5 Keypad ============ Introduction ------------ A keypad is a rectangular array of buttons. In this project, We will use it input characters. Components ---------- .. image:: img/list_2.1.5_keypad.png Principle --------- **Keypad** A keypad is a rectangular array of 12 or 16 OFF-(ON) buttons. Their contacts are accessed via a header suitable for connection with a ribbon cable or insertion into a printed circuit board. In some keypads, each button connects with a separate contact in the header, while all the buttons share a common ground. .. image:: img/image314.png More often, the buttons are matrix encoded, meaning that each of them bridges a unique pair of conductors in a matrix. This configuration is suitable for polling by a microcontroller, which can be programmed to send an output pulse to each of the four horizontal wires in turn. During each pulse, it checks the remaining four vertical wires in sequence, to determine which one, if any, is carrying a signal. Pullup or pulldown resistors should be added to the input wires to prevent the inputs of the microcontroller from behaving unpredictably when no signal is present. Schematic Diagram ----------------- .. image:: img/image315.png .. image:: img/image316.png Experimental Procedures ----------------------- **Step 1:** Build the circuit. .. image:: img/image186.png :width: 800 For C Language Users ^^^^^^^^^^^^^^^^^^^^^^ **Step 2:** Open the code file. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/c/2.1.5/ **Step 3:** Compile the code. .. raw:: html .. code-block:: gcc 2.1.5_Keypad.cpp -lwiringPi **Step 4:** Run. .. raw:: html .. code-block:: sudo ./a.out After the code runs, the values of pressed buttons on keypad (button Value) will be printed on the screen. .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`. **Code** .. code-block:: c #include #include #define ROWS 4 #define COLS 4 #define BUTTON_NUM (ROWS * COLS) unsigned char KEYS[BUTTON_NUM] { '1','2','3','A', '4','5','6','B', '7','8','9','C', '*','0','#','D'}; unsigned char rowPins[ROWS] = {1, 4, 5, 6}; unsigned char colPins[COLS] = {12, 3, 2, 0}; void keyRead(unsigned char* result); bool keyCompare(unsigned char* a, unsigned char* b); void keyCopy(unsigned char* a, unsigned char* b); void keyPrint(unsigned char* a); void keyClear(unsigned char* a); int keyIndexOf(const char value); void init(void) { for(int i=0 ; i<4 ; i++) { pinMode(rowPins[i], OUTPUT); pinMode(colPins[i], INPUT); } } int main(void){ unsigned char pressed_keys[BUTTON_NUM]; unsigned char last_key_pressed[BUTTON_NUM]; if(wiringPiSetup() == -1){ //when initialize wiring failed,print message to screen printf("setup wiringPi failed !"); return 1; } init(); while(1){ keyRead(pressed_keys); bool comp = keyCompare(pressed_keys, last_key_pressed); if (!comp){ keyPrint(pressed_keys); keyCopy(last_key_pressed, pressed_keys); } delay(100); } return 0; } void keyRead(unsigned char* result){ int index; int count = 0; keyClear(result); for(int i=0 ; i .. code-block:: cd ~/davinci-kit-for-raspberry-pi/python/ **Step 3:** Run. .. raw:: html .. code-block:: sudo python3 2.1.5_Keypad.py After the code runs, the values of pressed buttons on keypad (button Value) will be printed on the screen. **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``. .. raw:: html .. code-block:: python import RPi.GPIO as GPIO import time class Keypad(): def __init__(self, rowsPins, colsPins, keys): self.rowsPins = rowsPins self.colsPins = colsPins self.keys = keys GPIO.setwarnings(False) GPIO.setmode(GPIO.BCM) GPIO.setup(self.rowsPins, GPIO.OUT, initial=GPIO.LOW) GPIO.setup(self.colsPins, GPIO.IN, pull_up_down=GPIO.PUD_DOWN) def read(self): pressed_keys = [] for i, row in enumerate(self.rowsPins): GPIO.output(row, GPIO.HIGH) for j, col in enumerate(self.colsPins): index = i * len(self.colsPins) + j if (GPIO.input(col) == 1): pressed_keys.append(self.keys[index]) GPIO.output(row, GPIO.LOW) return pressed_keys def setup(): global keypad, last_key_pressed rowsPins = [18,23,24,25] colsPins = [10,22,27,17] keys = ["1","2","3","A", "4","5","6","B", "7","8","9","C", "*","0","#","D"] keypad = Keypad(rowsPins, colsPins, keys) last_key_pressed = [] def loop(): global keypad, last_key_pressed pressed_keys = keypad.read() if len(pressed_keys) != 0 and last_key_pressed != pressed_keys: print(pressed_keys) last_key_pressed = pressed_keys time.sleep(0.1) # Define a destroy function for clean up everything after the script finished def destroy(): # Release resource GPIO.cleanup() if __name__ == '__main__': # Program start from here try: setup() while True: loop() except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the program destroy() will be executed. destroy() **Code Explanation** .. code-block:: python def setup(): global keypad, last_key_pressed rowsPins = [18,23,24,25] colsPins = [10,22,27,17] keys = ["1","2","3","A", "4","5","6","B", "7","8","9","C", "*","0","#","D"] keypad = Keypad(rowsPins, colsPins, keys) last_key_pressed = [] Declare each key of the matrix keyboard to the array keys[] and define the pins on each row and column. .. code-block:: python def loop(): global keypad, last_key_pressed pressed_keys = keypad.read() if len(pressed_keys) != 0 and last_key_pressed != pressed_keys: print(pressed_keys) last_key_pressed = pressed_keys time.sleep(0.1) This is the part of the main function that reads and prints the button value. The function keyRead() will read the state of every button. The statement if len(pressed_keys) != 0 and last_key_pressed != pressed_keys is used to judge whether a key is pressed and the state of the pressed button. (If you press \'3\' when you press \'1\', the judgement is tenable.) Prints the value of the currently pressed key when the condition is tenable. The statement last_key_pressed = pressed_keys assigns the state of each judgment to an array last_key_pressed to facilitate the next round of conditional judgment. .. code-block:: python def read(self): pressed_keys = [] for i, row in enumerate(self.rowsPins): GPIO.output(row, GPIO.HIGH) for j, col in enumerate(self.colsPins): index = i * len(self.colsPins) + j if (GPIO.input(col) == 1): pressed_keys.append(self.keys[index]) GPIO.output(row, GPIO.LOW) return pressed_keys This function assigns a high level to each row in turn, and when the button in the column is pressed, the column in which the key is located gets a high level. After the two-layer loop is judged, the value of the button whose state is 1 is stored in the array pressed_keys. If you press the key \'3\': .. image:: img/image187.png rowPins[0] is written in high level, and colPins[2] gets high level. colPins[0]、colPins[1]、colPins[3] get low level. There are four states:0, 0, 1, 0; and we write \'3\' into pressed_keys. When rowPins[1] , rowPins[2] , rowPins[3] are written into high level, colPins[0] ~ colPins[4] get low level. The loop stopped, there returns pressed_keys = \'3\'. If you press the buttons \'1\' and \'3\', there will return pressed_keys = [\'1\',\'3\']. Phenomenon Picture ------------------ .. image:: img/image188.jpeg
