.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
1.3.4 Relay
In this lesson, we will learn to use a relay. It is one of the commonly
used components in automatic control system. When the voltage, current,
temperature, pressure, etc., reaches, exceeds or is lower than the
predetermined value, the relay will connect or interrupt the circuit, to
control and protect the equipment.
Components
.. image:: img/list_1.3.4.png
Principle
**Diode**
A diode is a two-terminal component in electronics with a unidirectional
flow of current. It offers low resistance in the direction of current
flow and offers high resistance in the opposite direction. Diodes are
mostly used to prevent damage to components, especially due to
electromotive force in circuits which are usually polarized.
.. image:: img/image344.png
The two terminals of a diode are polarized, with the positive end called
anode and the negative end called cathode. The cathode is usually made
of silver or has a color band. Controlling the direction of current flow
is one of the key features of diodes — the current in a diode flows from
anode to cathode. The behavior of a diode is similar to the behavior of
a check valve. One of the most important characteristics of a diode is
the non-linear current voltage. If higher voltage is connected to the
anode, then current flows from anode to cathode, and the process is
known as forward bias. However, if the higher voltage is connected to
the cathode, then the diode does not conduct electricity, and the
process is called reverse bias.
**Relay**
As we may know, relay is a device which is used to provide connection
between two or more points or devices in response to the input signal
applied. In other words, relays provide isolation between the controller
and the device as devices may work on AC as well as on DC. However, they
receive signals from a microcontroller which works on DC hence requiring
a relay to bridge the gap. Relay is extremely useful when you need to
control a large amount of current or voltage with small electrical
signal.
There are 5 parts in every relay:
**Electromagnet** - It consists of an iron core wounded by coil of
wires. When electricity is passed through, it becomes magnetic.
Therefore, it is called electromagnet.
**Armature** - The movable magnetic strip is known as armature. When
current flows through them, the coil is it energized thus producing a
magnetic field which is used to make or break the normally open (N/O) or
normally close (N/C) points. And the armature can be moved with direct
current (DC) as well as alternating current (AC).
**Spring** - When no currents flow through the coil on the
electromagnet, the spring pulls the armature away so the circuit cannot
be completed.
Set of electrical **contacts** - There are two contact points:
- Normally open - connected when the relay is activated, and disconnected when it is inactive.
- Normally close - not connected when the relay is activated, and connected when it is inactive.
**Molded frame** - Relays are covered with plastic for protection.
**Working of Relay**
The working principle of relay is simple. When power is supplied to the
relay, currents start flowing through the control coil; as a result, the
electromagnet starts energizing. Then the armature is attracted to the
coil, pulling down the moving contact together thus connecting with the
normally open contacts. So the circuit with the load is energized. Then
breaking the circuit would a similar case, as the moving contact will be
pulled up to the normally closed contacts under the force of the spring.
In this way, the switching on and off of the relay can control the state
of a load circuit.
.. image:: img/image142.jpeg
Schematic Diagram
.. image:: img/image345.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: img/image144.png
:width: 800
For C Language Users
**Step 2**: Open the code file.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/1.3.4
**Step 3:** Compile the code.
.. raw:: html
.. code-block::
gcc 1.3.4_Relay.c -lwiringPi
**Step 4:** Run the executable file.
.. raw:: html
.. code-block::
After the code runs, the LED will light up. In addition, you can
hear a ticktock caused by breaking normally close contact and
closing normally open contact.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`.
**Code**
.. code-block:: c
#include
#include
#define RelayPin 0
int main(void){
if(wiringPiSetup() == -1){ //when initialize wiring failed, print message to screen
pinMode(RelayPin, OUTPUT); //set GPIO17(GPIO0) output
// Tick
printf("Relay Open......\n");
delay(100);
digitalWrite(RelayPin, LOW);
delay(1000);
// Tock
printf("......Relay Close\n");
delay(100);
digitalWrite(RelayPin, HIGH);
delay(1000);
**Code Explanation**
.. code-block:: c
Set the I/O port as low level (0V), thus the transistor is not energized
and the coil is not powered. There is no electromagnetic force, so the
relay opens, LED does not turn on.
.. code-block:: c
set the I/O port as high level (5V) to energize the transistor. The coil
of the relay is powered and generate electromagnetic force, and the
relay closes, LED lights up.
For Python Language Users
**Step 2:** Open the code file.
.. raw:: html
.. code-block::
**Step 3:** Run.
.. raw:: html
.. code-block::
sudo python3 1.3.4_Relay.py
While the code is running, the LED lights up. In addition, you can hear
a ticktock caused by breaking normally close contact and closing
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``.
.. raw:: html
.. code-block:: python
import RPi.GPIO as GPIO
# Set GPIO17 as control pin
relayPin = 17
# Define a setup function for some setup
def setup():
GPIO.setmode(GPIO.BCM)
# Set relayPin's mode to output,
# and initial level to High(3.3v)
GPIO.setup(relayPin, GPIO.OUT, initial=GPIO.HIGH)
# Define a main function for main process
def main():
print ('Relay open...')
# Tick
GPIO.output(relayPin, GPIO.LOW)
time.sleep(1)
print ('...Relay close')
# Tock
GPIO.output(relayPin, GPIO.HIGH)
time.sleep(1)
# Define a destroy function for clean up everything after
# the script finished
def destroy():
# Turn off LED
# Release resource
GPIO.cleanup()
if __name__ == '__main__':
setup()
main()
# When 'Ctrl+C' is pressed, the child program
# destroy() will be executed.
destroy()
Set the pins of transistor as low level to let the relay open, LED does not turn on.
time.sleep(1)
wait for 1 second.
Set the pins of the transistor as low level to actuate the relay, LED
lights up.
Phenomenon Picture
.. image:: img/image145.jpeg
