.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! 1.3.2 Servo ============ Introduction -------------- In this lesson, we will learn how to make the servo rotate. Components ---------- .. image:: img/list_1.3.2.png Principle --------- **Servo** A servo is generally composed of the following parts: case, shaft, gear system, potentiometer, DC motor, and embedded board. .. image:: img/image121.png It works like this: The microcontroller sends out PWM signals to the servo, and then the embedded board in the servo receives the signals through the signal pin and controls the motor inside to turn. As a result, the motor drives the gear system and then motivates the shaft after deceleration. The shaft and potentiometer of the servo are connected together. When the shaft rotates, it drives the potentiometer, so the potentiometer outputs a voltage signal to the embedded board. Then the board determines the direction and speed of rotation based on the current position, so it can stop exactly at the right position as defined and hold there. .. image:: img/image122.png The angle is determined by the duration of a pulse that is applied to the control wire. This is called Pulse width Modulation. The servo expects to see a pulse every 20 ms. The length of the pulse will determine how far the motor turns. For example, a 1.5ms pulse will make the motor turn to the 90 degree position (neutral position). When a pulse is sent to a servo that is less than 1.5 ms, the servo rotates to a position and holds its output shaft some number of degrees counterclockwise from the neutral point. When the pulse is wider than 1.5 ms the opposite occurs. The minimal width and the maximum width of pulse that will command the servo to turn to a valid position are functions of each servo. Generally the minimum pulse will be about 0.5 ms wide and the maximum pulse will be 2.5 ms wide. .. image:: img/image123.jpeg Schematic Diagram ----------------- .. image:: img/image337.png Experimental Procedures ----------------------- **Step 1:** Build the circuit. .. image:: img/image125.png :width: 800 For C Language Users ^^^^^^^^^^^^^^^^^^^^^ **Step 2**: Go to the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/c/1.3.2 **Step 3**: Compile the code. .. raw:: html .. code-block:: gcc 1.3.2_Servo.c -lwiringPi **Step 4**: Run the executable file. .. raw:: html .. code-block:: sudo ./a.out After the program is executed, the servo will rotate from 0 degrees to 180 degrees, and then from 180 degrees to 0 degrees, circularly. .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`. **Code** .. code-block:: c #include #include #include #define ServoPin 1 //define the servo to GPIO1 long Map(long value,long fromLow,long fromHigh,long toLow,long toHigh){ return (toHigh-toLow)*(value-fromLow) / (fromHigh-fromLow) + toLow; } void setAngle(int pin, int angle){ //Create a funtion to control the angle of the servo. if(angle < 0) angle = 0; if(angle > 180) angle = 180; softPwmWrite(pin,Map(angle, 0, 180, 5, 25)); } int main(void) { int i; if(wiringPiSetup() == -1){ //when initialize wiring failed,print message to screen printf("setup wiringPi failed !"); return 1; } softPwmCreate(ServoPin, 0, 200); //initialize PMW pin of servo while(1){ for(i=0;i<181;i++){ // Let servo rotate from 0 to 180. setAngle(ServoPin,i); delay(2); } delay(1000); for(i=181;i>-1;i--){ // Let servo rotate from 180 to 0. setAngle(ServoPin,i); delay(2); } delay(1000); } return 0; } **Code Explanation** .. code-block:: c long Map(long value,long fromLow,long fromHigh,long toLow,long toHigh){ return (toHigh-toLow)*(value-fromLow) / (fromHigh-fromLow) + toLow; } Create a Map() function to map value in the following code. .. code-block:: c void setAngle(int pin, int angle){ //Create a funtion to control the angle of the servo. if(angle < 0) angle = 0; if(angle > 180) angle = 180; softPwmWrite(pin,Map(angle, 0, 180, 5, 25)); } Create a funtion, setAngle() to write angle to the servo. .. code-block:: c softPwmWrite(pin,Map(angle,0,180,5,25)); This function can change the duty cycle of the PWM. To make the servo rotate to 0 ~ 180 °, the pulse width should change within the range of 0.5ms ~ 2.5ms when the period is 20ms; in the function, softPwmCreate(), we have set that the period is 200x100us=20ms, thus we need to map 0 ~ 180 to 5x100us ~ 25x100us. The prototype of this function is shown below. .. code-block:: int softPwmCreate(int pin,int initialValue,int pwmRange); **Parameter pin:** Any GPIO pin of Raspberry Pi can be set as PWM pin. **Parameter initialValue:** The initial pulse width is that initialValue times 100us. **Parameter pwmRange:** the period of PWM is that pwmRange times 100us. For Python Language Users ^^^^^^^^^^^^^^^^^^^^^^^^^ **Step 2**: Go to the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/python/ **Step 3**: Run the executable file. .. raw:: html .. code-block:: sudo python3 1.3.2_Servo.py After the program is executed, the servo will rotate from 0 degrees to 180 degrees, and then from 180 degrees to 0 degrees, circularly. **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``. .. raw:: html .. code-block:: python import RPi.GPIO as GPIO import time SERVO_MIN_PULSE = 500 SERVO_MAX_PULSE = 2500 ServoPin = 18 def map(value, inMin, inMax, outMin, outMax): return (outMax - outMin) * (value - inMin) / (inMax - inMin) + outMin def setup(): global p GPIO.setmode(GPIO.BCM) # Numbers GPIOs by BCM GPIO.setup(ServoPin, GPIO.OUT) # Set ServoPin's mode is output GPIO.output(ServoPin, GPIO.LOW) # Set ServoPin to low p = GPIO.PWM(ServoPin, 50) # set Frequecy to 50Hz p.start(0) # Duty Cycle = 0 def setAngle(angle): # make the servo rotate to specific angle (0-180 degrees) angle = max(0, min(180, angle)) pulse_width = map(angle, 0, 180, SERVO_MIN_PULSE, SERVO_MAX_PULSE) pwm = map(pulse_width, 0, 20000, 0, 100) p.ChangeDutyCycle(pwm)#map the angle to duty cycle and output it def loop(): while True: for i in range(0, 181, 5): #make servo rotate from 0 to 180 deg setAngle(i) # Write to servo time.sleep(0.002) time.sleep(1) for i in range(180, -1, -5): #make servo rotate from 180 to 0 deg setAngle(i) time.sleep(0.001) time.sleep(1) def destroy(): p.stop() GPIO.cleanup() if __name__ == '__main__': #Program start from here setup() try: loop() except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the program destroy() will be executed. destroy() **Code Explanation** .. code-block:: python p = GPIO.PWM(ServoPin, 50) # set Frequecy to 50Hz p.start(0) # Duty Cycle = 0 Set the servoPin to PWM pin, then the frequency to 50hz, and the period to 20ms. p.start(0): Run the PWM function,and set the initial value to 0. .. code-block:: python def setAngle(angle): # make the servo rotate to specific angle (0-180 degrees) angle = max(0, min(180, angle)) pulse_width = map(angle, 0, 180, SERVO_MIN_PULSE, SERVO_MAX_PULSE) pwm = map(pulse_width, 0, 20000, 0, 100) p.ChangeDutyCycle(pwm)#map the angle to duty cycle and output it Create a function, setAngle() to write angle that ranges from 0 to 180 into the servo. .. code-block:: python angle = max(0, min(180, angle)) This code is used to limit the angle within the range 0-180°. The min() function returns the minimum of the input values. If 180angle, then return 0, if not, return angle. .. code-block:: python pulse_width = map(angle, 0, 180, SERVO_MIN_PULSE, SERVO_MAX_PULSE) pwm = map(pulse_width, 0, 20000, 0, 100) p.ChangeDutyCycle(pwm) To render a range 0 ~ 180 ° to the servo, the pulse width of the servo is set to 0.5ms(500us)-2.5ms(2500us). The period of PWM is 20ms(20000us), thus the duty cycle of PWM is (500/20000)%-(2500/20000)%, and the range 0 ~ 180 is mapped to 2.5 ~ 12.5. Phenomenon Picture ------------------ .. image:: img/image126.jpeg
