.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
š Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
1.2.2 Passive Buzzer
In this lesson, we will learn how to make a passive buzzer play music.
Components
.. image:: img/list_1.2.2.png
Schematic Diagram
In this experiment, a passive buzzer, a PNP transistor and a 1k resistor
are used between the base of the transistor and GPIO to protect the
transistor.
When GPIO17 is given different frequencies, the passive buzzer will emit
different sounds; in this way, the buzzer plays music.
.. image:: img/image333.png
Experimental Procedures
**Step 1**: Build the circuit.
.. image:: img/image106.png
:width: 800
For C Language Users
**Step 2**: Change directory.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/1.2.2/
**Step 3**: Compile.
.. raw:: html
.. code-block::
gcc 1.2.2_PassiveBuzzer.c -lwiringPi
**Step 4**: Run.
.. raw:: html
.. code-block::
The code run, the buzzer plays a piece of music.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`.
**Code**
.. code-block:: c
#include
#include
#include
#define BuzPin 0
#define CL1 131
#define CL2 147
#define CL3 165
#define CL4 175
#define CL5 196
#define CL6 221
#define CL7 248
#define CM1 262
#define CM2 294
#define CM3 330
#define CM4 350
#define CM5 393
#define CM6 441
#define CM7 495
#define CH1 525
#define CH2 589
#define CH3 661
#define CH4 700
#define CH5 786
#define CH6 882
#define CH7 990
int song_1[] = {CM3,CM5,CM6,CM3,CM2,CM3,CM5,CM6,CH1,CM6,CM5,CM1,CM3,CM2,
CM2,CM3,CM5,CM2,CM3,CM3,CL6,CL6,CL6,CM1,CM2,CM3,CM2,CL7,
CL6,CM1,CL5};
int beat_1[] = {1,1,3,1,1,3,1,1,1,1,1,1,1,1,3,1,1,3,1,1,1,1,1,1,1,2,1,1,
1,1,1,1,1,1,3};
int song_2[] = {CM1,CM1,CM1,CL5,CM3,CM3,CM3,CM1,CM1,CM3,CM5,CM5,CM4,CM3,CM2,
CM2,CM3,CM4,CM4,CM3,CM2,CM3,CM1,CM1,CM3,CM2,CL5,CL7,CM2,CM1
int beat_2[] = {1,1,1,3,1,1,1,3,1,1,1,1,1,1,3,1,1,1,2,1,1,1,3,1,1,1,3,3,2,3};
int main(void)
int i, j;
if(softToneCreate(BuzPin) == -1){
printf("setup softTone failed !");
printf("music is being played...\n");
delay(100);
for(i=0;i
.. code-block::
**Step 3: Run.**
.. raw:: html
.. code-block::
sudo python3 1.2.2_PassiveBuzzer.py
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``.
.. raw:: html
.. code-block:: python
import RPi.GPIO as GPIO
Buzzer = 11
CL = [0, 131, 147, 165, 175, 196, 211, 248] # Frequency of Bass tone in C major
CM = [0, 262, 294, 330, 350, 393, 441, 495] # Frequency of Midrange tone in C major
CH = [0, 525, 589, 661, 700, 786, 882, 990] # Frequency of Treble tone in C major
song_1 = [ CM[3], CM[5], CM[6], CM[3], CM[2], CM[3], CM[5], CM[6], # Notes of song1
CH[1], CM[6], CM[5], CM[1], CM[3], CM[2], CM[2], CM[3],
CM[5], CM[2], CM[3], CM[3], CL[6], CL[6], CL[6], CM[1],
CM[2], CM[3], CM[2], CL[7], CL[6], CM[1], CL[5] ]
beat_1 = [ 1, 1, 3, 1, 1, 3, 1, 1, # Beats of song 1, 1 means 1/8 beat
1, 1, 1, 1, 1, 1, 3, 1,
1, 3, 1, 1, 1, 1, 1, 1,
1, 2, 1, 1, 1, 1, 1, 1,
1, 1, 3 ]
song_2 = [ CM[1], CM[1], CM[1], CL[5], CM[3], CM[3], CM[3], CM[1], # Notes of song2
CM[1], CM[3], CM[5], CM[5], CM[4], CM[3], CM[2], CM[2],
CM[3], CM[4], CM[4], CM[3], CM[2], CM[3], CM[1], CM[1],
CM[3], CM[2], CL[5], CL[7], CM[2], CM[1] ]
beat_2 = [ 1, 1, 2, 2, 1, 1, 2, 2, # Beats of song 2, 1 means 1/8 beat
1, 1, 2, 2, 1, 1, 3, 1,
1, 2, 2, 1, 1, 2, 2, 1,
1, 2, 2, 1, 1, 3 ]
def setup():
GPIO.setmode(GPIO.BOARD) # Numbers GPIOs by physical location
GPIO.setup(Buzzer, GPIO.OUT) # Set pins' mode is output
global Buzz # Assign a global variable to replace GPIO.PWM
Buzz = GPIO.PWM(Buzzer, 440) # 440 is initial frequency.
Buzz.start(50) # Start Buzzer pin with 50% duty cycle
def loop():
print ('\n Playing song 1...')
for i in range(1, len(song_1)): # Play song 1
Buzz.ChangeFrequency(song_1[i]) # Change the frequency along the song note
time.sleep(beat_1[i] * 0.5) # delay a note for beat * 0.5s
time.sleep(1) # Wait a second for next song.
print ('\n\n Playing song 2...')
for i in range(1, len(song_2)): # Play song 1
Buzz.ChangeFrequency(song_2[i]) # Change the frequency along the song note
time.sleep(beat_2[i] * 0.5) # delay a note for beat * 0.5s
def destory():
Buzz.stop() # Stop the buzzer
GPIO.output(Buzzer, 1) # Set Buzzer pin to High
GPIO.cleanup() # Release resource
setup()
loop()
destory()
**Code Explanation**
These are the frequencies of each note. The first 0 is to
skip CL[0] so that the number 1-7 corresponds to the CDEFGAB of the tone.
These arrays are the notes of a song.
beat_1 = [ 1, 1, 3, 1, 1, 3, 1, 1, 1, 1, 1, 1, 1, 1, 3, 1,
1, 3, 1, 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1,
1, 1, 3 ]
Every sound beat (each number) represents the ā
beat, or 0.5s
Buzz.start(50)
Define pin Buzzer as PWM pin, then set its frequency to 440 and
Buzz.start(50) is used to run PWM. Whatās more, set the duty cycle to 50%.
Run a for loop, then the buzzer will play the notes in the array song_1[]
with the beats in the beat_1[] array, .
Now you can hear the passive buzzer playing music.
Phenomenon Picture
.. image:: img/image107.jpeg
