.. include:: /index.rst
:start-after: start_hello_message
:end-before: end_hello_message
.. _assemble_hat:
.. start_assemble_hat
Assemble and Power on Fusion HAT+ (Important)
Connect Fusion HAT+ to Raspberry Pi
Here, we'll teach you how to assemble the Fusion HAT+.
#. Assemble the base.
#. Stick the battery to the base.
#. Secure the Raspberry Pi with with standoffs.
#. Connect the FPC cable to the Raspberry Pi. (We will assemble it and the Camera Module when assembled the pan-tilt.)
#. Plug the Fusion HAT+ into the 40-pin connector on the Raspberry Pi.
#. **Insert the battery.** (This is very important. If you don't insert the battery, the Fusion HAT+ will not work.)
For the details of the assembly, please check the video below.
.. raw:: html
Charge
Before the first use, it is recommended to fully charge the battery. You can use the included USB Type-C charging cable, or your own USB-C charger.
.. note::
The battery may arrive with low charge because Amazon requires it to be below 30% before air shipment. You **MUST** fully charge it before use to prevent over-discharge and damage.
Plug the USB-C to Fusion HAT+, and the battery will be charged automatically. You don't need to connect the power supply to the Raspberry Pi.
* We recommend using a **5V 3A power supply**, such as the official Raspberry Pi 15W adapter.
* You can also use a **USB-C PD (Power Delivery)** charger or a **QC 2.0 fast charger**.
* Charging from 0% to full typically takes about **2 hours**.
.. image:: img/power_charge.jpg
:width: 400
:align: center
The Fusion HAT+ includes **two battery indicator LEDs**, showing the battery voltage level:
.. list-table::
:header-rows: 1
:widths: 40 40
* - LED Status
- Battery Voltage
* - 2 LEDs ON
- > 7.4V
* - 1 LED ON
- < 7.4V
* - Both LEDs OFF
- < 6.5V
When charging, one of the LEDs will blink to indicate charging progress:
.. list-table::
:header-rows: 1
:widths: 40 40
* - LED Status
- Battery Voltage
* - 1 LED ON, 1 LED Blinking
- > 7.4V
* - Only 1 LED Blinking
- < 7.4V
After fully charged:
* **If the Fusion HAT+ is ON**, both LEDs will remain lit.
* **If the Fusion HAT+ is OFF**, both LEDs will turn off.
.. note::
For extended programming or debugging sessions, you can keep the Fusion HAT+ powered
by connecting the USB-C cable, which will charge the battery and run the Fusion HAT+ at the same time.
Even if you run the Fusion HAT+ while the charer is connected, the battery **cannot** be removed.
Power ON
When the battery has sufficient charge, press the **power button** on the Fusion HAT+ briefly.
* The **PWR LED** will turn on.
* The **battery LEDs** will also light up.
* The Raspberry Pi will power on automatically.
.. image:: img/power_button.jpg
:width: 400
.. end_assemble_hat
.. _assemble_fusion_hat_pan_tilt:
Assemble the Pan-tilt (For Camera)
To make using the camera module easier, you can assemble a pan-tilt.
.. note::
Assembling the pan-tilt may obscure some pins, so it is recommended to assemble it only when using the camera, or place it on the outside after assembly.
.. image:: img/gimbal_assemble.png
.. raw:: html
