3-pin Battery
../../_images/3pin_battery_blue.jpg
  • VCC: Battery positive terminal, here there are two sets of VCC and GND is to increase the current and reduce the resistance.
  • Middle: To balance the voltage between the two cells and thus protect the battery.
  • GND: Negative battery terminal.
This is a custom battery pack made by SunFounder consisting of two 18650 batteries with a capacity of 2000mAh. The connector is XH2.54 3P, which can be charged directly after being inserted into the Robot HAT.
Features
  • Composition: Li-ion
  • Battery Capacity: 2000mAh, 14.8Wh
  • Battery Weight: 90.8g
  • Number of Cells: 2
  • Connector: XH2.54 3P
  • Over-discharge protection: 6.0V
