5.10 ShiftOut(Segment Display)¶
Previously, we used the shiftout()
function to light up eight LEDs; here we use it to display 0-9 on the 7-aegment Display.
The 7-segment Display is essentially a device packaged by 8 LEDs, of which 7 strip-shaped LEDs form an “8” shape, and there is a slightly smaller dotted LED as a decimal point. These LEDs are marked as a, b, c, d, e, f, g, and dp. They have their own anode pins and share cathodes. Their pin locations are shown in the figure below.
Schematic
74HC595 |
LED Segment Display |
Q0 |
a |
Q1 |
b |
Q2 |
c |
Q3 |
d |
Q4 |
e |
Q5 |
f |
Q6 |
g |
Q7 |
dp |
Open the
5.10.shiftout_segment.ino
file under the path of3in1-kit\learning_project\5.10.shiftout_segment
.Or copy this code into Arduino IDE.
Or upload the code through the Arduino Web Editor.
After the code is uploaded successfully, you will be able to see the LED Segment Display display 0~9 in sequence.
How it works?
shiftOut()
will make 74HC595 output 8 digital signals.
It outputs the last bit of the binary number to Q0,
and the output of the first bit to Q7. In other words,
writing the binary number “00000001” will make Q0 output high level and Q1~Q7 output low level.
Suppose that the 7-segment Display display the number “2”, we need to write a high level for a, b, d, e and g, and write a low level for c, f and dp. That is, the binary number ” 01011011” needs to be written. For readability, we will use hexadecimal notation as “0x5b”.
Similarly, we can also make the 7-Segment Display display other numbers in the same way. The following table shows the codes corresponding to these numbers.
Numbers |
Binary Code |
Hex Code |
0 |
00111111 |
0x3f |
00000110 |
0x06 |
01011011 |
0x5b |
01001111 |
0x4f |
01100110 |
0x66 |
01101101 |
0x6d |
01111101 |
0x7d |
7 |
00000111 |
0x07 |
8 |
01111111 |
0x7f |
9 |
01101111 |
0x6f |
Write these codes into shiftOut()
to make the LED Segment Display display the corresponding numbers.
