9. Remote Control
This kit comes with an IR receiver, which allows you to use an IR remote control to control the movement of the car.
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
SunFounder R3 Board
L298N Module
TT Motor
LED
IR Receiver
Now build the circuit according to the diagram below.
IR Receiver
R3 Board
OUT
12
GND
GND
VCC
5V
LED
R3 Board
Anode(The longer pin)
13
Cathode
GND
../_images/car_remote.jpg
  • Open the 9.remote_control.ino file under the path of 3in1-kit\car_project\9.remote_control.
  • The IRremote library is used here, you can install it from the Library Manager.
    ../_images/lib_irremote.png
After the code is uploaded successfully, press the button on the remote control, the LED will blink once to represent that the signal has been received, and the car will move according to the button you pressed. You can press the following keys to control the car.
  • +: Accelerate
  • -: Decelerate
  • 1: Forward to the left
  • 2: Forward
  • 3: Forward to the right
  • 4: Turn left
  • 6: Turn right
  • 7: Backward to the left
  • 8: Backward
  • 9: Backward to the right
How it works?
The effect of this project is to make the car move by reading the key value of the IR remote control. In addition, an LED is added to indicate that the IR signal has been successfully received.
  1. Import the IRremote library, you can install it from the Library Manager.
    #include <IRremote.h>
    const int IR_RECEIVE_PIN = 12;  // Define the pin number for the IR Sensor
    String lastDecodedValue = "";   // Variable to store the last decoded value
  2. Initialize the IR receiver and the LED.
    const int ledPin = 13;
        //IR remote
        IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);  // Start the IR receiver // Start the receiver
        Serial.println("REMOTE CONTROL START");
        //LED
        pinMode(ledPin, OUTPUT);
  3. When you press the keys on the remote control, the LED will blink and the infrared receiver will know which key is pressed, and then the car will move according to the corresponding key value.
        if (IrReceiver.decode()) {
            //    Serial.println(results.value,HEX);
            String key = decodeKeyValue(IrReceiver.decodedIRData.command);
            if (key != "ERROR" && key != lastDecodedValue) {
                Serial.println(key);
                lastDecodedValue = key;  // Update the last decoded value
                blinkLED();
                if (key == "+") {
                    speed += 50;
                } else if (key == "-") {
                    speed -= 50;
                } else if (key == "2") {
                    moveForward(speed);
                    delay(1000);
                IrReceiver.resume();  // Enable receiving of the next value
    • Checks if an IR signal is received and successfully decoded.
    • Decodes the IR command and stores it in key using a custom decodeKeyValue() function.
    • Checks if the decoded value is not an error and is different from the last decoded value.
    • Prints the decoded IR value to the serial monitor.
    • Updates the lastDecodedValue with the new decoded value.
    • Resumes IR signal reception for the next signal.
  4. About the blinkLED() function.
    When this function is called, have the LED repeat the toggle from on-off three times so that you see the LED blink 3 times.
    void blinkLED() {
            for (int i = 0; i < 3; i++) {
            digitalWrite(ledPin, HIGH);
            delay(50);
            digitalWrite(ledPin, LOW);
            delay(50);
