5.11.1 Liquid Crystal Display¶
An I2C LCD1602 is composed of an LCD1602 and an I2C module, LCD1602 can be used to display characters, numbers, etc., but need to take up a lot of pins of the main control, after configuring an I2C module, only 2 I/0 pins are needed to drive this LCD1602.
Now look at how to make this I2C CDL1602 work.
3 in 1 Starter Kit |
380+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
The SDA and SCL of the R3 board are the pins A4 and A5.
Open the
5.11.liquid_crystal_display.ino
file under the path of3in1-kit\basic_project\5.11.liquid_crystal_display
.Or copy this code into Arduino IDE.
The
LiquidCrystal I2C
library is used here, you can install it from the Library Manager.
After the code is uploaded successfully, you will see “SunFounder”, “Hello World” on the I2C LCD1602.
If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back.
How it works?
By calling the library LiquidCrystal_I2C.h
, you can easily drive the LCD.
#include "LiquidCrystal_I2C.h"
Library Functions:
LiquidCrystal_I2C(uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows)
Creates a new instance of the LiquidCrystal_I2C
class that represents a
particular LCD attached to your Arduino board.
lcd_AddR
: The address of the LCD defaults to 0x27.lcd_cols
: The LCD1602 has 16 columns.lcd_rows
: The LCD1602 has 2 rows.
void init()
Initialize the lcd.
void backlight()
Turn the (optional) backlight on.
void nobacklight()
Turn the (optional) backlight off.
void display()
Turn the LCD display on.
void nodisplay()
Turn the LCD display off quickly.
void clear()
Clear display, set cursor position to zero.
void setCursor(uint8_t col,uint8_t row)
Set the cursor position to col,row.
void print(data,BASE)
Prints text to the LCD.
data
: The data to print (char, byte, int, long, or string).BASE (optional)
: The base in which to print numbers: BIN for binary (base 2), DEC for decimal (base 10), OCT for octal (base 8), HEX for hexadecimal (base 16).
