.. _car_remote_plus: 10. One Touch Start ============================= In this project, we have integrated the previous projects - line following, following, obstacle avoidance, self-driving, etc. together. They can be switched by buttons on the remote control, so you can start the car and experience all functions at once. **Wiring** .. image:: img/car_all.png :width: 800 **Code** .. note:: * Open the ``10.one_touch_start.ino`` file under the path of ``3in1-kit\car_project\10.one_touch_start``. * Or copy this code into **Arduino IDE**. * The ``IRremote`` library is used here, you can install it from the **Library Manager**. .. image:: ../img/lib_irremote.png .. raw:: html After the code is uploaded successfully, the LED will flash rapidly 3 times for every signal received from the remote control by the IR receiver. You can press the following keys to operate the cart. * **+**: Accelerate * **-**: Decelerate * **1**: Move to the left front * **2**: Forward * **3**: Move to the right. * **4**: Turn left * **6**: Turn right * **7**: Backward to the left * **8**: Backward. * **9**: Backward to the right * **CYCLE**: Follow the line * **U/SD**: Self-driving * **▷▷|**: Obstacle avoidance with ultrasonic module * **|◁◁**: Obstacle avoidance with IR Obstacle module * **EQ**: Follow your hand * **0**: Stop
