How to create, open or Save the Sketch? ======================================= #. When you open the Arduino IDE for the first time or create a new sketch, you will see a page like this, where the Arduino IDE creates a new file for you, which is called a "sketch". .. image:: img/sp221014_173458.png These sketch files have a regular temporary name, from which you can tell the date the file was created. ``sketch_oct14a.ino`` means October 14th first sketch, ``.ino`` is the file format of this sketch. #. Now let's try to create a new sketch. Copy the following code into the Arduino IDE to replace the original code. .. image:: img/create1.png .. code-block:: C void setup() { // put your setup code here, to run once: pinMode(13,OUTPUT); } void loop() { // put your main code here, to run repeatedly: digitalWrite(13,HIGH); delay(500); digitalWrite(13,LOW); delay(500); } #. Press ``Ctrl+S`` or click **File** -> **Save**. The Sketch is saved in: ``C:\Users\{your_user}\Documents\Arduino`` by default, you can rename it or find a new path to save it. .. image:: img/create2.png #. After successful saving, you will see that the name in the Arduino IDE has been updated. .. image:: img/create3.png Please continue with the next section to learn how to upload this created sketch to your Arduino board.
