.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _iot_home: 5. Home Environment Monitoring ================================================ In this chapter, we will use Blynk to create a home environment monitor. You can measure the temperature, humidity, and light intensity of a room using the DHT11 and photoresistor. By sending these values to Blynk, you will be able to know the environment of your home via the internet. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_esp8266` - |link_esp8266_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_photoresistor` - |link_photoresistor_buy| * - :ref:`cpn_dht11` - \- **1. Build the Circuit** .. note:: The ESP8266 module requires a high current to provide a stable operating environment, so make sure the 9V battery is plugged in. .. image:: img/wiring_dht11.jpg **2. Edit Dashboard** #. For recording humidity values, create a **Datastream** of type **Virtual Pin** on the **Datastream** page. Set the DATA TYPE to **Double** and MIN and MAX to **0** and **100**. Also set the units to **Percentage, %**. .. image:: img/sp220610_145748.png #. Then create a **Datastream** of type **Virtual Pin** for recording the temperature. Set DATA TYPE to ``Double``, MIN and MAX to ``-30`` and ``50``, and units to **Celsius, °C**. .. image:: img/sp220610_145811.png #. Also create a **Datastream** of type **Virtual Pin** to record the light intensity. Use the default data type - **Integer**, with MIN and MAX set to ``0`` and ``1024``. .. image:: img/sp220610_145834.png #. Go to the **Wed Dashboard** page, drag two **Label** widgets and set their data streams to **V4** and **V5** respectively, and drag a **Gauge** widget and set the data stream to **V6**. Also in the widget setting, you can enable **Change color based on value** and select the appropriate color to make the widget look better and more intuitive. .. image:: img/sp220610_150400.png :align: center **3. Run the Code** #. Open the ``5.home_environment_monitoring.ino`` file under the path of ``3in1-kit\iot_project\5.home_environment_monitoring``, or copy this code into **Arduino IDE**. .. note:: * The ``DHT sensor library`` is used here, you can install it from the **Library Manager**. .. image:: ../img/lib_dht11.png .. raw:: html #. Replace the ``Template ID``, ``Device Name``, and ``Auth Token`` with your own. You also need to enter the ``ssid`` and ``password`` of the WiFi you are using. For detailed tutorials, please refer to :ref:`connect_blynk`. #. After selecting the correct board and port, click the **Upoad** button. #. Open the Serial monitor(set baudrate to 115200) and wait for a prompt such as a successful connection to appear. .. image:: img/2_ready.png .. note:: If the message ``ESP is not responding`` appears when you connect, please follow these steps. * Make sure the 9V battery is plugged in. * Reset the ESP8266 module by connecting the pin RST to GND for 1 second, then unplug it. * Press the reset button on the R3 board. Sometimes, you may need to repeat the above operation 3-5 times, please be patient. #. Now, you will see the current ambient temperature, humidity and light intensity on Blynk. .. image:: img/sp220610_150400.png :align: center #. If you want to use Blynk on mobile devices, please refer to :ref:`blynk_mobile`. .. image:: img/mobile_home.jpg **How it works?** These two functions are used to get the temperature, humidity and light intensity of the room. .. code-block:: arduino int readLight(){ return analogRead(lightPin); } bool readDHT() { // Reading temperature or humidity takes about 250 milliseconds! // Sensor readings may also be up to 2 seconds 'old' (it's a very slow sensor) humidity = dht.readHumidity(); // Read temperature as Celsius (the default) temperature = dht.readTemperature(); // Check if any reads failed and exit early (to try again). if (isnan(humidity) || isnan(temperature)) { Serial.println("Failed to read from DHT sensor!"); return false; } return true; } With the Blynk ``Timer``, the ambient temperature, humidity, and light intensity are obtained every second and sent to the data stream on the Blynk Cloud, from which the widgets display the data. .. code-block:: arduino void myTimerEvent() { bool chk = readDHT(); int light = readLight(); if(chk){ Blynk.virtualWrite(V4,humidity); Blynk.virtualWrite(V5,temperature); } Blynk.virtualWrite(V6,light); }
