.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _iot_gate: 7. Current Limiting Gate ================================== Some situations, such as parking lots, require quantity management. Here we create a smart gate: a servo is used as the gate, and an IR obstacle detector is placed in front of it; if an object (like a car) is detected, the gate will open and the number will be increased by 1. The count is displayed with a 7-segment display and is also uploaded to the Blynk Cloud for you to view remotely. Finally, Blynk has a Switch widget to enable or disable this smart gate system. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_esp8266` - |link_esp8266_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_servo` - |link_servo_buy| * - :ref:`cpn_avoid` - |link_obstacle_avoidance_buy| * - :ref:`cpn_7_segment` - |link_7segment_buy| * - :ref:`cpn_74hc595` - |link_74hc595_buy| **1. Build the Circuit** .. note:: The ESP8266 module requires a high current to provide a stable operating environment, so make sure the 9V battery is plugged in. .. image:: img/wiring_servo_segment.jpg :width: 800 **2. Edit Dashboard** #. To record the number, create a **Datastream** of type **Virtual Pin** on the **Datastream** page. Set DATA TYPE to ``Integer`` and MIN and MAX to ``0`` and ``10``. .. image:: img/sp220610_165328.png #. Now go to the **Wed Dashboard** page, drag a **Switch** widget to set its data stream to **V0** and a **Label** widget to set its data stream to **V8**. .. image:: img/sp220610_165548.png **3. Run the Code** #. Open the ``7.current_limiting_gate.ino`` file under the path of ``3in1-kit\iot_project\7.current_limiting_gate``, or copy this code into **Arduino IDE**. .. raw:: html #. Replace the ``Template ID``, ``Device Name``, and ``Auth Token`` with your own. You also need to enter the ``ssid`` and ``password`` of the WiFi you are using. For detailed tutorials, please refer to :ref:`connect_blynk`. #. After selecting the correct board and port, click the **Upoad** button. #. Open the Serial monitor(set baudrate to 115200) and wait for a prompt such as a successful connection to appear. .. image:: img/2_ready.png .. note:: If the message ``ESP is not responding`` appears when you connect, please follow these steps. * Make sure the 9V battery is plugged in. * Reset the ESP8266 module by connecting the pin RST to GND for 1 second, then unplug it. * Press the reset button on the R3 board. Sometimes, you may need to repeat the above operation 3-5 times, please be patient. #. Now click on the Button Control widget on Blynk to enable the smart door system. If the IR obstacle avoidance module detects an obstacle, the gate will open and the 7-segment display and the Count widget on Blynk will add 1. .. image:: img/sp220610_165548.png #. If you want to use Blynk on mobile devices, please refer to :ref:`blynk_mobile`. .. image:: img/mobile_gate.jpg **How it works?** The function ``BLYNK_WRITE(V0)`` gets the status of the **Switch** widget and assigns it to the variable ``doorFlag``, which will be used to determine if the smart gate system is enabled or not. .. code-block:: arduino BLYNK_WRITE(V0) { doorFlag = param.asInt(); // Enable Gate } In the Blynk Timer, ``doorFlag`` is judged every second and if it is enabled, the main function of the gate is executed. .. code-block:: arduino void myTimerEvent() { if (doorFlag) { channelEntrance(); } } The main function of the gate is ``channelEntrance()``. When an object approaches the gate (the sensor detects that there is an obstacle), the ``count`` is increased by 1. Write ``count`` to the datastream ``V8`` of Blynk Cloud and 7-segment display on the circuit, and open the door. If the object goes from present to absent, which means the object has entered the door, close the door. .. code-block:: arduino void channelEntrance() { int currentState = digitalRead(irPin); // 0:obstacle 1:no-obstacle if (currentState == 0 && lastState == 1) { count=(count+1)%10; Blynk.virtualWrite(V8, count); showNumber(count); operateGate(true); } else if ((currentState == 1 && lastState == 0)) { operateGate(false); } lastState = currentState; } The function ``showNumber(int num)`` is used to make the 7-segment display show the value. .. code-block:: arduino void showNumber(int num) { digitalWrite(STcp, LOW); //ground ST_CP and hold low for as long as you are transmitting shiftOut(DS, SHcp, MSBFIRST, datArray[num]); digitalWrite(STcp, HIGH); //pull the ST_CPST_CP to save the data } The function ``operateGate(bool openGate)`` slowly opens the door when the reference is ``True``, and slowly closes the door when the reference is ``False``. .. code-block:: arduino void operateGate(bool openGate) { if (openGate == true) { // open gate while (angle <= 90) { angle++; myservo.write(angle); delay(5); } } else { // close gate while (angle >= 0){ angle--; myservo.write(angle); delay(5); } } }
