.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _iot_music: 4. Cloud Music Player ===================================== The goal of this project is to create a music player using Blynk. Music is played in the same way as in :ref:`ar_passive_buzzer`, by writing the song in the program and playing it with a passive buzzer. however, in this example, we can click the switch to play/pause and slide the slider to change the playback progress. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_esp8266` - |link_esp8266_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_buzzer` - |link_passive_buzzer_buy| **1. Build the Circuit** .. note:: The ESP8266 module requires a high current to provide a stable operating environment, so make sure the 9V battery is plugged in. .. image:: img/wiring_buzzer.jpg **2. Edit Dashboard** #. Create a **Datastream** of type **Virtual Pin** on the **Datastream** page as the value modified by the Slider widget added later or code. Set the DATA TYPE to **Integer** and MIN and MAX to **0** and **30**. .. image:: img/sp220610_104330.png #. Also create another **Datastream** of type **Virtual Pin** to display the music name, and set the DATA TYPE to ``String``. .. image:: img/sp220610_105932.png #. Go to the **Wed Dashboard** page, drag a **Switch** widget and set **Datastream** to V0 (V0 is already set in :ref:`iot_blink`); drag a **Label** widget and set it to V3; drag a **Slider** widget and set it to V2. .. image:: img/blynk_music_cloud.png .. note:: Your virtual pins may be different from mine, yours will prevail, but you need to modify the corresponding pin number in the code. **3. Run the Code** #. Open the ``4.cloud_music_player.ino`` file under the path of ``3in1-kit\iot_project\4.cloud_music_player``. .. raw:: html #. Replace the ``Template ID``, ``Device Name``, and ``Auth Token`` with your own. You also need to enter the ``ssid`` and ``password`` of the WiFi you are using. For detailed tutorials, please refer to :ref:`connect_blynk`. #. After selecting the correct board and port, click the **Upoad** button. #. Open the Serial monitor(set baudrate to 115200) and wait for a prompt such as a successful connection to appear. .. image:: img/2_ready.png .. note:: If the message ``ESP is not responding`` appears when you connect, please follow these steps. * Make sure the 9V battery is plugged in. * Reset the ESP8266 module by connecting the pin RST to GND for 1 second, then unplug it. * Press the reset button on the R3 board. Sometimes, you may need to repeat the above operation 3-5 times, please be patient. #. Now, you can use Blynk's Button Control widget to start/pause the music and the Slider to adjust the playback progress, and you'll also see the name of the music. .. image:: img/blynk_music_cloud.png #. If you want to use Blynk on mobile devices, please refer to :ref:`blynk_mobile`. **How it works?** The datastream **V0** is used to get the status of the Switch widget and assign it to the variable **musicPlayFlag**, which controls pausing and playing the music. .. code-block:: arduino int musicPlayFlag=0; BLYNK_WRITE(V0) { musicPlayFlag = param.asInt(); // START/PAUSE MUSIC } The data stream **V2** is used to get the value of the slider widget and assign it to the variable **scrubBar** when the slider is moved. .. code-block:: arduino int scrubBar=0; BLYNK_WRITE(V2) { scrubBar=param.asInt(); } When the device is connected to the **Blynk Cloud**, write the music name for the **V3** datastream and then display it with the **Label** widget. .. code-block:: arduino BLYNK_CONNECTED() { String songName = "Ode to Joy"; Blynk.virtualWrite(V3, songName); } **Blynk Timer** will execute every second. Music is played if **musicPlayFlag** is not 0, i.e. the **Switch** widget is ON. As soon as two notes are played, the progress bar variable ``scrubBar`` is incremented by 2, and the value is then written to the **Blynk Cloud**, which synchronizes the value of the **Slider** widget. .. code-block:: arduino void myTimerEvent() { if(musicPlayFlag!=0) { tone(buzzerPin,melody[scrubBar],250); scrubBar=(scrubBar+1)%(sizeof(melody)/sizeof(int)); delay(500); tone(buzzerPin,melody[scrubBar],250); scrubBar=(scrubBar+1)%(sizeof(melody)/sizeof(int)); Serial.println(scrubBar); Blynk.virtualWrite(V2, scrubBar); } }
