.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _car_ultrasonic:
6. Play with Ultrasonic Module
In :ref:`car_ir_obstacle` project, the 2 infrared obstacle avoidance modules are used for obstacle avoidance, but the detection distance of IR obstacle avoidance module is short, which may make the car too late to avoid the obstacles.
In this project, we use ultrasonic module to do some long-distance detection, so that the car can sense obstacles at a farther distance to make a judgment.
**Required Components**
It's definitely convenient to buy a whole kit, here's the link:
.. list-table::
:widths: 20 20 20
:header-rows: 1
* - Name
- ITEMS IN THIS KIT
- LINK
* - 3 in 1 Starter Kit
- 380+
- |link_3IN1_kit|
.. list-table::
:widths: 30 20
:header-rows: 1
* - COMPONENT INTRODUCTION
- PURCHASE LINK
* - :ref:`cpn_uno`
- |link_Uno_R3_buy|
* - :ref:`cpn_l9110`
* - :ref:`cpn_tt_motor`
* - :ref:`cpn_ultrasonic`
- |link_ultrasonic_buy|
**Wiring**
An ultrasonic sensor module is an instrument that measures the distance to an object using ultrasonic sound waves.
It has two probes. One is to send ultrasonic waves and the other is to receive the waves and transform the time of sending and receiving into a distance, thus detecting the distance between the device and an obstacle.
.. raw:: html
Now build the circuit according to the following diagram.
.. list-table::
:header-rows: 1
* - Ultrasonic Module
- R3 Board
* - Vcc
- 5V
* - Trig
- 3
* - Echo
- 4
* - Gnd
- GND
.. image:: img/car_6.png
:width: 800
**Code**
.. note::
* Open the ``6.ultrasonic_module.ino`` file under the path of ``3in1-kit\car_project\6.ultrasonic_module``.
* Or copy this code into **Arduino IDE**.
* Or upload the code through the `Arduino Web Editor `_.
.. raw:: html
After the code is successfully uploaded, turn the car towards the wall. If the distance is too far, it will move forward; if it is too close, it will move backward; if it is at a safe distance, it will stop.
**How it works?**
This project is based on the distance read by the ultrasonic module to make the car move accordingly.
#. Add the pin definition for the ultrasonic module, ``trigPin`` is used to transmit ultrasonic wave, so set it to ``OUTPUT``; ``echoPin`` is set to ``INPUT`` to receive ultrasonic wave.
.. code-block:: arduino
const int trigPin = 3;
const int echoPin = 4;
//ultrasonic
pinMode(echoPin, INPUT);
pinMode(trigPin, OUTPUT);
#. First read the distance value obtained from the ultrasonic module, if the distance is greater than 25, let the car move forward; if the distance is between 2-10cm, let the car move backward, otherwise (between 10~25) stop.
float distance = readSensorData();
if (distance > 25) {
moveForward(200);
else if (distance < 10 && distance > 2) {
moveBackward(200);
} else {
stopMove();
#. About ``readSensorData()`` function.
The transmitter of the ultrasonic module transmits a 10us square wave signal every 2us, and the receiver receives a high level signal if there is an obstacle within the range. Use the ``pulseIn()`` function to record the time from sending to receiving, divide by the speed of sound 340m/s, and then divide by 2, the result is the distance between this module and the obstacle with units: cm.
float readSensorData() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
float distance = pulseIn(echoPin, HIGH) / 58.00; //Equivalent to (340m/s*1us)/2
return distance;
* `pulseIn(pin, value) `_
* ``pin``: the number of the Arduino pin on which you want to read the pulse. Allowed data types: int.
* ``value``: type of pulse to read: either HIGH or LOW. Allowed data types: int.
Reads a pulse (either HIGH or LOW) on a pin. For example, if value is HIGH, ``pulseIn()`` waits for the pin to go from LOW to HIGH, starts timing, then waits for the pin to go LOW and stops timing.
