.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _car_speed: 3. Speed Up =================== In addition to the digital signal (HIGH/LOW), the input of L9110 module can also receive PWM signal to control the speed of the output. In other words, we can use ``AnalogWrite()`` to control the moving speed of the car. In this project, we let the car gradually change its forward speed, first accelerating and then decelerating. **Wiring** This project is the same wiring as :ref:`car_move_code`. **Code** .. note:: * Open the ``3.speed_up.ino`` file under the path of ``3in1-kit\car_project\3.speed_up``. * Or copy this code into **Arduino IDE**. * Or upload the code through the `Arduino Web Editor `_. .. raw:: html After the program runs, the car will gradually accelerate and then gradually decelerate. **How it works?** The purpose of this project is to write different PWM values to the input pins of the L9110 module to control the forward speed of the car. #. Use the ``for()`` statement to give ``speed`` in steps of 5, writing values from 0 to 255 so you can see the change in the car's forward speed. .. code-block:: arduino void loop() { for(int i=0;i<=255;i+=5){ moveForward(i); delay(500); } for(int i=255;i>=0;i-=5){ moveForward(i); delay(500); } } #. About the ``moveForward()`` function. As opposed to :ref:`car_move_code` which directly gives high/low levels to the input pins of the L9110 module, here we pass a parameter ``speed`` to where we need to give high levels. .. code-block:: arduino void moveForward(int speed) { analogWrite(A_1B, 0); analogWrite(A_1A, speed); analogWrite(B_1B, speed); analogWrite(B_1A, 0); } * `for `_ The ``for`` statement is used to repeat a block of statements enclosed in curly braces. An increment counter is usually used to increment and terminate the loop. .. code-block:: arduino for (initialization; condition; increment) { // statement(s); } * ``initialization``: happens first and exactly once. * ``condition``: each time through the loop, condition is tested; if it's true, the statement block, and the increment is executed, then the condition is tested again. When the condition becomes false, the loop ends. * ``increment``: executed each time through the loop when condition is true.
