.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _car_assemble: Assemble the Car ===================== **Video** .. raw:: html **Steps** Please follow the steps below to complete the assembly of the car. 1. Remove the protective film on the acrylic. .. image:: img/IMG_9118.JPG 2. Place the board on the table as shown in the picture, the side with the same hole as the R3 board, we call A; the back is B. This will help you avoid mistakes during assembly. .. image:: img/IMG_9145.JPG #. Mount the **M3x24mm standoff** with **M3x6mm screws** in the position as shown below. .. image:: img/IMG_9151.JPG #. Turn to the B side, use **M3x30mm screws** and **M3 nuts** to attach the TT Motor. 2 details here: 1 - the output shaft is facing the bat-shaped side; 2 - the motor cable is facing the inside. .. image:: img/IMG_9153.JPG #. Mount another TT Motor, the same attention needs to be paid to the direction of the output shaft and the direction of the cable. .. image:: img/IMG_9154.JPG #. Use **M3x6mm screws** to mount the **M3x12mm standoff** in the position as shown below. .. image:: img/IMG_9157.JPG #. Attach the **M2.5x11mm standoff** to the rear of the car with **M2.5x6mm screws**. .. image:: img/IMG_9174.JPG #. Use **M3x6mm screws** to mount the universal wheel. .. image:: img/IMG_9175.JPG #. Putting on the 2 wheels and the car's basic structure has been completed. .. image:: img/IMG_9179.JPG #. Attach the L9110 module with **M2.5x6mm screws**. .. image:: img/IMG_9182.JPG #. Assemble the two IR Obstacle Modules with **M3x12mm screws** and **M3 nuts**. .. image:: img/IMG_9185.JPG #. Turn to side B and attach the Line Track module with four **M3x6mm screws** and two **M3x24mm standoffs**. .. note:: It's advisable to first secure the **M3x24mm standoffs** onto the Line Track module. One important note to keep in mind: the pins of the line sensor are slightly soft and protrude a bit towards the holes. When screwing in the **M3x24mm standoffs**, apply gentle pressure to push aside the sensor pins slightly. .. image:: img/IMG_9186.JPG #. Stick the velcro on the 9V battery and put on the battery clip. Stick the other section of the Velcro on the car to secure the battery. .. image:: img/IMG_9189.JPG #. Turn over to side A and mount the R3 board with **M3x6mm screws**. .. image:: img/IMG_9196.JPG #. Attach the breadboard to the front of the car. Thereafter, you will be able to add different components (e.g. ultrasonic module) to the breadboard as required for your project. .. image:: img/IMG_9197.JPG #. Getting the car running also requires wiring it up and writing code, which will be written in subsequent sections.
