.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ar_analog_read: 4. Analog Read ====================== The Arduino can read the connected analog sensors through the analog pins. The R3 board contains a multi-channel, 10-bit analog-to-digital converter. This means it maps the input voltage between 0 and the operating voltage (5V or 3.3V) to an integer value between 0 and 1023. You need the ``analogRead(pin)`` function to read the value of the analog pin. * ``analogRead(pin)``: Read the value from the specified analog pin. **Syntax** analogRead(pin) **Parameters** * ``pin``: the name of the analog input pin to read from (A0 to A5). **Returns** 0-1023. Data type: int. **Example of Analog Read** .. code-block:: arduino int analogPin = A0; // device connected to analog pin A0 // outside leads to ground and +5V int val = 0; // variable to store the value read void setup() { Serial.begin(9600); // setup serial } void loop() { val = analogRead(analogPin); // read the input pin Serial.println(val); // debug value } **Notes and Warnings** * The analog pins are A0-A5. * You don't need to call ``pinMode()`` before calling the analog pin, but if the pin was previously set to ``OUTPUT``, the function ``analogRead()`` will not work properly, in which case you need to call ``pinMode()`` to set it back to ``INTPUT``. **Related Components** Below are the related components, you can click in to learn how to use them. .. toctree:: :maxdepth: 2 ar_turn_the_knob ar_photoresistor ar_joystick ar_moisture ar_thermistor
