.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ar_servo: 5.5 Use Internal Library ======================================= In the Arduino IDE, you can use many built-in libraries by adding the corresponding ``.h`` file directly to your code. This project uses the ``Servo`` library to drive the Servo, so that it can rotate between 0° and 180°. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_servo` - |link_servo_buy| **Schematic** .. image:: img/circuit_6.2_servo.png In this project, we use PWM pin 9 to drive the Servo, and get the orange wire of the servo connected to the PWM pin 9, the red one to 5V, and the brown one to GND. **Wiring** .. image:: img/swinging_servo_bb.jpg **Code** .. note:: * Open the ``5.5.use_internal_library.ino`` file under the path of ``3in1-kit\basic_project\5.5.use_internal_library``. * Or copy this code into **Arduino IDE**. * Or upload the code through the `Arduino Web Editor `_. .. raw:: html Once you finish uploading the codes to the R3 board, you can see the servo arm rotating in the range 0°~180°. **How it works?** By calling the library ``Servo.h``, you can drive the servo easily. .. code-block:: arduino #include Library Functions: .. code-block:: arduino Servo Create **Servo** object to control a servo. .. code-block:: arduino uint8_t attach(int pin); Call ``pinMode()`` to turn a pin into a servo driver and return 0 on failure. .. code-block:: arduino void detach(); Release a pin from servo driving. .. code-block:: arduino void write(int value); Set the angle of the servo in degrees, 0 to 180. .. code-block:: arduino int read(); Return that value set with the last ``write()``. .. code-block:: arduino bool attached(); Return 1 if the servo is currently attached.
