.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ar_state_change: 5.3 State Change Detection =========================== When the button controls other devices, it can not only work when it is pressed, but stop when it is released. It is also possible to switch the working state each time the button is pressed. In order to achieve this effect, you need to know how to toggle the working state between off and on when the button is pressed, That is "state change detection". In this project, we will use the button to control the motor. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_button` - |link_button_buy| * - :ref:`cpn_tt_motor` - \- * - :ref:`cpn_l9110` - \- **Schematic** .. image:: img/circuit_8.3_statechange.png **Wiring** .. image:: img/5.3_state_change_l9110_bb.png :width: 800 :align: center **Code** .. note:: * Open the ``5.3.state_change_detection.ino`` file under the path of ``3in1-kit\basic_project\5.3.state_change_detection``. * Or copy this code into **Arduino IDE**. * Or upload the code through the `Arduino Web Editor `_. .. raw:: html After the code is uploaded successfully, you press the button and the motor will turn; until you press the button again, the motor will stop. **How it works?** #. Create variables and define pins for the motor and button. .. code-block:: arduino ... int detectionState = 0; int buttonState = 0; int lastButtonState = 0; * ``detectionState`` is a flag whose value changes each time the button is pressed, e.g., 0 this time, 1 the next, and so on alternately. * ``buttonState`` and ``lastButtonState`` are used to record the state of the button this time and the last time, to compare whether the button was pressed or released. #. Initialize each pin and set the baud rate of the serial monitor. .. code-block:: arduino void setup() { pinMode(buttonPin, INPUT); Serial.begin(9600); pinMode(B_1A, OUTPUT); pinMode(B_1B, OUTPUT); } #. First read the state of the button, and if the button is pressed, the variable ``detectionState`` will switch its value from 0 to 1 or 1 to 0. When ``detectionState`` is 1, the motor will be turned. It has the effect that this time the button is pressed, the motor turns, the next time the button is pressed, the motor stops, and so on alternately. .. code-block:: arduino void loop() { // Toggle the detectionState each time the button is pressed buttonState = digitalRead(buttonPin); if (buttonState != lastButtonState) { if (buttonState == HIGH) { detectionState=(detectionState+1)%2; Serial.print("The detection state is: "); Serial.println(detectionState); } delay(50); } lastButtonState = buttonState; // According to the detectionState, start the motor if(detectionState==1){ digitalWrite(B_1A,HIGH); digitalWrite(B_1B,LOW); }else{ digitalWrite(B_1A,LOW); digitalWrite(B_1B,LOW); } } The entire workflow is as follows. * Read the button value. .. code-block:: arduino buttonState = digitalRead(buttonPin); * If ``buttonState`` and ``lastButtonState`` are not equal, it means that the button state has changed, continue with the next judgment, and store the button state at this time into the variable ``lastButtonState``. ``delay(50)`` is used to eliminate jitter. .. code-block:: arduino if (buttonState != lastButtonState) { ... delay(50); } lastButtonState = buttonState; * When the button is pressed, its value is HIGH. Here, when the button is pressed, the value of the variable ``detectionState`` is changed, e.g., from 0 to 1 after an operation. .. code-block:: arduino if (buttonState == HIGH) { detectionState=(detectionState+1)%2; Serial.print("The detection state is: "); Serial.println(detectionState); } * When the variable ``detectionState`` is 1, let the motor rotate, otherwise stop. .. code-block:: arduino if(detectionState==1){ digitalWrite(B_1A,HIGH); digitalWrite(B_1B,LOW); }else{ digitalWrite(B_1A,LOW); digitalWrite(B_1B,LOW); }
