.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ar_map: 5.6 Map =================== If you observe carefully, you will notice that many values have different ranges in programming. For example, the range of values for analog inputs is (0~1023). The value range for the analog output is (0~255). The output angle of the servo is (0~180). This means that if we want to use the potentiometer to control the brightness of the LED or the angle of the servo, we need to go through a mapping operation. Now let's see how to achieve it. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_servo` - |link_servo_buy| * - :ref:`cpn_potentiometer` - |link_potentiometer_buy| **Schematic** .. image:: img/circuit_8.3_amp.png **Wiring** .. image:: img/map_bb.jpg :width: 800 :align: center **Code** .. note:: * Open the ``5.6.map.ino`` file under the path of ``3in1-kit\basic_project\5.6.map``. * Or copy this code into **Arduino IDE**. * Or upload the code through the `Arduino Web Editor `_. .. raw:: html After the code is uploaded successfully, you can rotate the potentiometer back and forth, and the output shaft of the servo will rotate back and forth. **How it works?** ``map(value, fromLow, fromHigh, toLow, toHigh)``: Map a number from one range to another. That is, a fromLow value is mapped to toLow, and a fromHigh value is mapped to toHigh. **Syntax** map(value, fromLow, fromHigh, toLow, toHigh) **Parameters** * ``value``: the number to map. * ``fromLow``: the lower bound of the value's current range. * ``fromHigh``: the upper bound of the value's curr+ent range. * ``toLow``: the lower bound of the value's target range. * ``toHigh``: the upper bound of the value's target range. If the potentiometer controls the LED, you can also use the map to complete the task. .. code-block:: arduino int x = analogRead(knob); int y = map(x,0,1023,0,255); analogWrite(led,y); **Notes and Warnings** * The "lower bound" of both ranges may be larger or smaller than the "upper bound", which means that the ``map()`` function can be used to reverse a range of numbers. .. code-block:: arduino y = map(x,0,180,180,0); * Mapping also works well for negative numbers. .. code-block:: arduino y = map(x,0,1023,-90,90); * The mapping uses integers, and the decimal places of floats are discarded.
