.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ar_lcd1602: 5.11.1 Liquid Crystal Display =============================== An I2C LCD1602 is composed of an LCD1602 and an I2C module, LCD1602 can be used to display characters, numbers, etc., but need to take up a lot of pins of the main control, after configuring an I2C module, only 2 I/0 pins are needed to drive this LCD1602. Now look at how to make this I2C CDL1602 work. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_i2c_lcd1602` - |link_i2clcd1602_buy| **Schematic** .. image:: img/circuit_7.1_lcd1602.png **Wiring** .. image:: img/lcd_bb.jpg :width: 800 :align: center .. note:: The SDA and SCL of the R3 board are the pins A4 and A5. **Code** .. note:: * Open the ``5.11.liquid_crystal_display.ino`` file under the path of ``3in1-kit\basic_project\5.11.liquid_crystal_display``. * Or copy this code into **Arduino IDE**. * The ``LiquidCrystal I2C`` library is used here, you can install it from the **Library Manager**. .. image:: ../img/lib_liquidcrystal_i2c.png .. raw:: html After the code is uploaded successfully, you will see "SunFounder", "Hello World" on the I2C LCD1602. .. note:: If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back. **How it works?** By calling the library ``LiquidCrystal_I2C.h``, you can easily drive the LCD. .. code-block:: arduino #include "LiquidCrystal_I2C.h" Library Functions: .. code-block:: arduino LiquidCrystal_I2C(uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows) Creates a new instance of the ``LiquidCrystal_I2C`` class that represents a particular LCD attached to your Arduino board. * ``lcd_AddR``: The address of the LCD defaults to 0x27. * ``lcd_cols``: The LCD1602 has 16 columns. * ``lcd_rows``: The LCD1602 has 2 rows. .. code-block:: arduino void init() Initialize the lcd. .. code-block:: arduino void backlight() Turn the (optional) backlight on. .. code-block:: arduino void nobacklight() Turn the (optional) backlight off. .. code-block:: arduino void display() Turn the LCD display on. .. code-block:: arduino void nodisplay() Turn the LCD display off quickly. .. code-block:: arduino void clear() Clear display, set cursor position to zero. .. code-block:: arduino void setCursor(uint8_t col,uint8_t row) Set the cursor position to col,row. .. code-block:: arduino void print(data,BASE) Prints text to the LCD. * ``data``: The data to print (char, byte, int, long, or string). * ``BASE (optional)``: The base in which to print numbers: BIN for binary (base 2), DEC for decimal (base 10), OCT for octal (base 8), HEX for hexadecimal (base 16).
