.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ar_receiver: 5.11.2 IR Receiver ========================= In this project, you will learn to use IR Receiver. An infrared-receiver is a component which receives infrared signals and can independently receive infrared rays and output signals compatible with TTL level. It is similar with a normal plastic-packaged transistor in size and is suitable for all kinds of infrared remote control and infrared transmission. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_receiver` - \- **Schematic** .. image:: img/circuit_7.2_receiver.png **Wiring** In this example, we wire up the left pin of IR Receiver to pin 11, the middle pin to GND, and the right pin to 5V. .. image:: img/ir_remote_control_bb.jpg **Code** .. note:: * Open the ``5.11.ir_receiver.ino`` file under the path of ``3in1-kit\basic_project\5.11.ir_receiver``. * Or copy this code into **Arduino IDE**. * The ``IRremote`` library is used here, you can install it from the **Library Manager**. .. image:: ../img/lib_irremote.png .. raw:: html After uploading the codes to the R3 board, you can see that the current value of the pressed button of IR Remote Controller displays on the serial monitor. **How it works?** This code is designed to work with an infrared (IR) remote control using the ``IRremote`` library. Here's the breakdown: #. Include Libraries: This includes the ``IRremote`` library, which provides functions to work with IR remote controls. .. code-block:: arduino #include #. Defines the Arduino pin to which the IR sensor's signal pin is connected. .. code-block:: arduino const int IR_RECEIVE_PIN = 11; // Define the pin number for the IR Sensor #. Initializes serial communication at a baud rate of 9600. Initializes the IR receiver on the specified pin (``IR_RECEIVE_PIN``) and enables LED feedback (if applicable). .. code-block:: arduino void setup() { Serial.begin(9600); // Start serial communication at 9600 baud rate IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK); // Start the IR receiver } #. The loop runs continuously to process incoming IR remote signals. .. code-block:: arduino void loop() { if (IrReceiver.decode()) { String decodedValue = decodeKeyValue(IrReceiver.decodedIRData.command); if (decodedValue != "ERROR") { Serial.println(decodedValue); delay(100); } IrReceiver.resume(); // Enable receiving of the next value } } * Checks if an IR signal is received and successfully decoded. * Decodes the IR command and stores it in ``decodedValue`` using a custom ``decodeKeyValue()`` function. * Checks if the decoded value is not an error. * Prints the decoded IR value to the serial monitor. * Resumes IR signal reception for the next signal.
