.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ar_interval: 5.4 Interval ================ Sometimes you need to do two things at once. For example you might want to blink an LED while reading a button press. In this case, you can't use ``delay()``, because Arduino pauses your program during the ``delay()``. If the button is pressed while Arduino is paused waiting for the ``delay()`` to pass, your program will miss the button press. An analogy would be warming up a pizza in your microwave, and also waiting some important email. You put the pizza in the microwave and set it for 10 minutes. The analogy to using ``delay()`` would be to sit in front of the microwave watching the timer count down from 10 minutes until the timer reaches zero. If the important email arrives during this time you will miss it. What you would do in real life would be to turn on the pizza, and then check your email, and then maybe do something else (that doesn't take too long!) and every so often you will come back to the microwave to see if the timer has reached zero, indicating that your pizza is done. This sketch demonstrates how to tone an buzzer without using ``delay()``. It turns the buzzer on and then makes note of the time. Then, each time through ``loop()``, it checks to see if the desired interval time has passed. If it has, it tone the buzzer and makes note of the new time. In this way the buzzer tones continuously while the sketch execution never lags on a single instruction. Based on this condition, we can add the code of the button to control the LED, it will not be disturbed by the buzzer playing music. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_led` - |link_led_buy| * - :ref:`cpn_button` - |link_button_buy| * - :ref:`cpn_buzzer` - |link_passive_buzzer_buy| **Schematic** .. image:: img/circuit_8.5_interval.png **Wiring** .. image:: img/interval_bb.jpg :width: 600 :align: center **Code** .. note:: * Open the ``5.4.interval.ino`` file under the path of ``3in1-kit\basic_project\5.4.interval``. * Or copy this code into **Arduino IDE**. * Or upload the code through the `Arduino Web Editor `_. .. raw:: html After the code is uploaded successfully, the buzzer will play music; whenever you press the button, the LED will light up. The work of LED and buzzer does not interfere with each other. **How it works?** Initial a variable named ``previousMillis`` to store previous operating time of microcontroller. .. code-block:: arduino unsigned long previousMillis = 0; Mark which note is played. .. code-block:: arduino int thisNote=0; The interval time of each note. .. code-block:: arduino long interval = 1000; In ``loop()``, declare ``currentMillis`` to store the current time. .. code-block:: arduino unsigned long currentMillis = millis(); When the interval between the current operating time and last updating time is larger than 1000ms, certain functions are triggered. Meanwhile, update the previousMillis to the current time for the next triggering that is to happen 1 second latter. .. code-block:: arduino if (currentMillis - previousMillis >= interval) { previousMillis = currentMillis;// save the last time of the last tone //... } Play the notes in the melody one by one. .. code-block:: arduino tone(buzzerPin,melody[thisNote],100); interval=1000/noteDurations[thisNote]; // interval at which to tone thisNote=(thisNote+1)%(sizeof(melody)/2); //iterate over the notes of the melody The button control the LED. .. code-block:: arduino // play button & led digitalWrite(ledPin,digitalRead(buttonPin));
