.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ar_74hc_7seg: 5.15 EEPROM ============== `EEPROM `_ is a memory, so the data it stores will not be erased when the main control board is turned off. You can use it to record some data and read it the next time you turn it on. As an example, you can make a sports counter that keeps track of how many rope skippings you do every day. You can also write data to it in one program and read it in another. For example, when you are working on a car project, the speeds of the two motors are inconsistent. You can write a calibration program to record the compensation value of the motor speed. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_led` - |link_led_buy| * - :ref:`cpn_servo` - |link_servo_buy| * - :ref:`cpn_button` - |link_button_buy| * - :ref:`cpn_potentiometer` - |link_potentiometer_buy| **Schematic** .. image:: img/circuit_515_eeprom.png **Wiring** .. image:: img/eeprom_servo.png **Code** .. note:: * Open the ``5.15.eeproom.ino`` file under the path of ``3in1-kit\basic_project\5.15.eeproom``. * Or copy this code into **Arduino IDE**. * Or upload the code through the `Arduino Web Editor `_. .. raw:: html To use this circuit, you simply press the button to begin recording and input the desired information through a potentiometer. Now, the board will repeat your actions endlessly (and it blinks an led each iteration) until you press the button again to record new actions. You may also vary the amount of time recorded by changing the values of resolution and recordTime. **How it works?** #. Import the ``EEPROM.h`` library, and initialize the EEPROM memory. .. code-block:: arduino ... #include //used to store recorded values ... float resolution = 1000;//MUST be less than EEPROM.length() float recordTime = 5; //delay time bool recording = false; ... Please note that ``/MUST be less than EEPROM.length()``, in ``setup()`` it will print the memory of your board's EEPROM, which should be 1024 for SunFounder R3 board. If you are using a different board, you can change the value of the variable ``resolution``. #. Print the EEPROM memory of your board. .. code-block:: arduino void setup() { ... Serial.begin(9600); //Serial.println(EEPROM.length()); } To find the size of your board's EEPROM memory, uncomment the line ``Serial.println(EEPROM.read(i))``. This will print the size of EEPROM in the serial monitor, and you can change the value of the variable ``resolution`` accordingly. #. As soon as a button press is detected, then recording begins and the required information is entered via a potentiometer. Now the board repeats your action endlessly (and flashes an LED for each repetition) until you press the button again, recording a new action. .. code-block:: arduino void loop() { if (recording == true) {//record for (int i = 1; i <= resolution; i++) { digitalWrite(ledPin, HIGH); //light status led int val = map(analogRead(A0), 0, 1023, 0, 180); EEPROM.write(i, val); //Serial.println(EEPROM.read(i)); myServo.write(val); delay(recordTime); } digitalWrite(ledPin, LOW); //turn off status led delay(1000);//give time for person recording = false; } else { for (int i = 1; i <= resolution; i++) {//playback if (digitalRead(buttonPin) == 0) {//stop playback and record new values recording = true; break; } int readval = EEPROM.read(i); myServo.write(readval); //Serial.println(readval); delay(recordTime); } digitalWrite(ledPin, HIGH); //show a new repeat delay(100); digitalWrite(ledPin, LOW); } } * Make the variable ``recording`` true when the button is pressed. * When the variable ``recording`` is true, start recording the action in the memory range. * Read the value of the potentiometer and map it to 0-180 to store it in EEPROM and control the rotation of the servo. * The LED lights up at the start of recording and goes off at the end. * Repeat the recorded action with a quick flash of the LED to remind you of a new repeat. #. About the ``EEPROM`` library. Here are some of its functions. * ``write(address,value)``: Write a byte to the EEPROM. * ``address``: the location to write to, starting from 0 (int) * ``value``: the value to write, from 0 to 255 (byte) * An EEPROM write takes 3.3 ms to complete. The EEPROM memory has a specified life of 100,000 write/erase cycles, so you may need to be careful about how often you write to it. * ``Read(address)``: Reads a byte from the EEPROM. Locations that have never been written to have the value of 255. * ``update(address,value)``: Write a byte to the EEPROM. The value is written only if differs from the one already saved at the same address. * An EEPROM write takes 3.3 ms to complete. The EEPROM memory has a specified life of 100,000 write/erase cycles, so using this function instead of write() can save cycles if the written data does not change often * ``EEPROM.put(address, data)``: Write any data type or object to the EEPROM. * ``address``: the location to read from, starting from 0 (int). * ``data``: the data to read, can be a primitive type (eg. float) or a custom struct. * This function uses EEPROM.update() to perform the write, so does not rewrites the value if it didn't change. * ``EEPROM.get(address, data)``: Read any data type or object from the EEPROM. * ``address``: the location to read from, starting from 0 (int). * ``data``: the data to read, can be a primitive type (eg. float) or a custom struct.
