.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ar_blink: 1.1 Hello, LED! ======================================= Just as printing “Hello, world!” is the first step in learning to program, using a program to drive an LED is the traditional introduction to learning physical programming. **Required Components** In this project, we need the following components. It's definitely convenient to buy a whole kit, here's the link: .. list-table:: :widths: 20 20 20 :header-rows: 1 * - Name - ITEMS IN THIS KIT - LINK * - 3 in 1 Starter Kit - 380+ - |link_3IN1_kit| You can also buy them separately from the links below. .. list-table:: :widths: 30 20 :header-rows: 1 * - COMPONENT INTRODUCTION - PURCHASE LINK * - :ref:`cpn_uno` - |link_Uno_R3_buy| * - :ref:`cpn_breadboard` - |link_breadboard_buy| * - :ref:`cpn_wires` - |link_wires_buy| * - :ref:`cpn_resistor` - |link_resistor_buy| * - :ref:`cpn_led` - |link_led_buy| **Schematic** .. image:: img/circuit_1.1_led.png The principle of this circuit is simple and the current direction is shown in the figure. When pin 9 outputs high level(5V), the LED will light up after the 220ohm current limiting resistor. When pin 9 outputs low level (0v), the LED will turn off. **Wiring** .. image:: img/wiring_led.png :width: 400 :align: center **Code** .. note:: * You can open the file ``1.1.hello_led.ino`` under the path of ``3in1-kit\basic_project\1.1.hello_led``. * Or copy this code into **Arduino IDE**. * Or upload the code through the `Arduino Web Editor `_. .. raw:: html After the code is uploaded successfully, you will see the LED blinking. **How it works?** Here, we connect the LED to the digital pin 9, so we need to declare an int variable called ledpin at the beginning of the program and assign a value of 9. .. code-block:: arduino const int ledPin = 9; Now, initialize the pin in the ``setup()`` function, where you need to initialize the pin to ``OUTPUT`` mode. .. code-block:: arduino void setup() { pinMode(ledPin, OUTPUT); } In ``loop()``, ``digitalWrite()`` is used to provide 5V high level signal for ledpin, which will cause voltage difference between LED pins and light LED up. .. code-block:: arduino digitalWrite(ledPin, HIGH); If the level signal is changed to LOW, the ledPin's signal will be returned to 0 V to turn LED off. .. code-block:: arduino digitalWrite(ledPin, LOW); An interval between on and off is required to allow people to see the change, so we use a ``delay(1000)`` code to let the controller do nothing for 1000 ms. .. code-block:: arduino delay(1000);
