.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! Arduino Program Structure =========================== Let's take a look at the new sketch file. Although it has a few lines of code itself, it is actually an "empty" sketch. Uploading this sketch to the development board will cause nothing to happen. .. code-block:: C void setup() { // put your setup code here, to run once: } void loop() { // put your main code here, to run repeatedly: } If we remove ``setup()`` and ``loop()`` and make the sketch a real ``blank`` file, you will find that it does not pass the verification. They are the equivalent of the human skeleton, and they are indispensable. During sketching, ``setup()`` is run first, and the code inside it (inside ``{}``) is run after the board is powered up or reset and only once. ``loop()`` is used to write the main feature, and the code inside it will run in a loop after ``setup()`` is executed. To better understand setup() and loop(), let's use four sketches. Their purpose is to make the on-board LED of the Arduino blink. Please run each experiment in turn and record them specific effects. * Sketch 1: Make the on-board LED blink continuously. .. code-block:: C :emphasize-lines: 8,9,10,11 void setup() { // put your setup code here, to run once: pinMode(13,OUTPUT); } void loop() { // put your main code here, to run repeatedly: digitalWrite(13,HIGH); delay(500); digitalWrite(13,LOW); delay(500); } * Sketch 2: Make the on-board LED blink only once. .. code-block:: C :emphasize-lines: 4,5,6,7 void setup() { // put your setup code here, to run once: pinMode(13,OUTPUT); digitalWrite(13,HIGH); delay(500); digitalWrite(13,LOW); delay(500); } void loop() { // put your main code here, to run repeatedly: } * Sketch 3: Make the on-board LED blink slowly once and then blink quickly. .. code-block:: C :emphasize-lines: 4,5,6,7,12,13,14,15 void setup() { // put your setup code here, to run once: pinMode(13,OUTPUT); digitalWrite(13,HIGH); delay(1000); digitalWrite(13,LOW); delay(1000); } void loop() { // put your main code here, to run repeatedly: digitalWrite(13,HIGH); delay(200); digitalWrite(13,LOW); delay(200); } * Sketch 4: Report an error. .. code-block:: C :emphasize-lines: 6,7,8,9 void setup() { // put your setup code here, to run once: pinMode(13,OUTPUT); } digitalWrite(13,HIGH); delay(1000); digitalWrite(13,LOW); delay(1000); void loop() { // put your main code here, to run repeatedly: } With the help of these sketches, we can summarize several features of ``setup-loop``. * ``loop()`` will be run repeatedly after the board is powered up. * ``setup()`` will run only once after the board is powered up. * After the board is powered up, ``setup()`` will run first, followed by ``loop()``. * The code needs to be written within the ``{}`` scope of ``setup()`` or ``loop()``, out of the framework will be an error. .. note:: Statements such as ``digitalWrite(13,HIGH)`` are used to control the on-board LED, and we will talk about their usage in detail in later chapters.
