.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _ar_digital_write: 1. Digital Write ============================== **Digital Write** is to output or write a digital signal to a digital pin. The digital signal has only two states, 0 or 1, 0V or 5V, so it allows some components, such as the LED and buzzer, to be on or off. On the Arduino R4 board, there are 14 digital I/0 pins from 0 to 13, now use the ``pinMode()`` and ``digitalWrite()`` functions to write a high or low level to these digital pins. * ``pinMode(pin, mode)``: Configure the specific pin as ``INPUT`` or ``OUTPUT``, here it needs to be set as ``OUTPUT``. **Syntax** pinMode(pin, mode) **Parameters** * ``pin``: the Arduino pin number to set the mode of. * ``mode``: ``INPUT``, ``OUTPUT``, or ``INPUT_PULLUP``. * ``digitalWrite(pin, value)``: Write a high level (5V) or a low level (0V) to a digital pin to change the operating state of the component. If the pin has been configured as an OUTPUT with pinMode(), its voltage will be set to the corresponding value: 5V (or 3.3V on 3.3V boards) for HIGH, 0V (ground) for LOW. **Syntax** digitalWrite(pin, value) **Parameters** * ``pin``: the Arduino pin number. * ``value``: ``HIGH`` or ``LOW``. **Example of Digital Write:** .. code-block:: arduino const int pin = 13; void setup() { pinMode(pin, OUTPUT); // sets the digital pin as output } void loop() { digitalWrite(pin, HIGH); // sets the digital pin on delay(1000); // waits for a second digitalWrite(pin, LOW); // sets the digital pin off delay(1000); // waits for a second } .. image:: img/1_led.jpg **Notes and Warnings** * The pins 0~13 are all digital pins. * Do not use pins 0 and 1, as they are used to communicate with the computer. Connecting anything to these pins will interfere with communication, including causing the upload board to fail. * If the digital pins are used up, the analog pins (A0-A5) can also be used as digital pins. **Related Components** Below are the related components, you can click in to learn how to use them. .. toctree:: :maxdepth: 2 ar_blinking_led ar_active_buzzer ar_turn_the_wheel ar_pumping
